Old 23-02-2005, 12:04 AM   #1 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
Default Outlook Holidays??
Outlook Holidays??
In my Outlook Calendar I added Indian Holidays yesterday.
[Tools > Options > Calendar Options > Add Holidays... > India]
Then I closed Outlook after a Send/Receive.
Today when I opened it... all holiday are listed twice... like on 15 Aug. entry for Indian Independence Day is twice, which should be only once by default.
Same for all holidays... for all years!!!
I want to remove one of these two entries for each holiday... how do I... ??
When I tried to remove it again by unchecking "India" from Holiday list... [Tools > Options > Calendar Options > Add Holidays... > India]
I get a message like this:
"Holidays for India already installed. Do you want to install them again?"
And if i chose Yes... it adds one more entry for all coming years for a holiday... if No... it doesn't add anything... but still double entry for all holidays left!!!!
... Is there any way... batch removal tool of one extra entry of each holiday from my cal???
Googled@max... nothing found :roll:
ShekharPalash is offline
Old 23-02-2005, 02:39 PM   #2 (permalink)
enoonmai's Avatar
In Calendar, on the View menu, point to Arrange By, point to Current View, and then click Events.
Select the holidays you want to remove. To select multiple rows, press the CTRL key and click subsequent rows and then click Delete.
Playing FEAR XP/LSW2
enoonmai is offline
- by gohan89
