Old 14-06-2007, 04:13 PM   #1 (permalink)
ramprasad's Avatar
Default ISO file on a DVD
Hi,
I have a ISO file of a Bootable CD.
Can I edit it and add many other data, so as to make it 3GB.? And write it on to a DVD...?
Will the DVD also be a bootable one or not...?
Any help wud be appreciated....!
ramprasad is offline
Old 14-06-2007, 04:56 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: ISO file on a DVD
Yes edit the ISO using UltraISO, MagicSO, WinISO etc
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 14-06-2007, 05:35 PM   #3 (permalink)
God of Mistakes...
Garbage's Avatar
Wink Re: ISO file on a DVD
off-course it will be unless & until u change it's BOOT SECTOR !!
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 14-06-2007, 06:09 PM   #4 (permalink)
ramprasad's Avatar
thanks a lot guys for replying....
sukhdeep .....how did u make ur avtar
share me the steps...
Old 14-06-2007, 06:10 PM   #5 (permalink)
Host4Cheap.org
I didnt Google Image Search Zindabad
Old 18-06-2007, 12:09 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
UltraISO ..... is great ........
ax3 is offline
Old 20-06-2007, 09:00 PM   #7 (permalink)
CA50's Avatar
hi buddy how 2 use Magic iso maker
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 20-06-2007, 09:10 PM   #8 (permalink)
Commander in Chief
QwertyManiac's Avatar
Its based on KOL's images of various countries' flags.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 20-06-2007, 10:25 PM   #9 (permalink)
clmlbx's Avatar
yes, ultra iso is best.
clmlbx is online now
To convert a .bat or a .vbs file into an executable .exe file without any software mneo Tutorials 4 03-06-2007 11:13 PM
i have a 2o mb rar file which becomes a 2gb iso file.how do i do it with other stuff? tango_cash Software Q&A 8 27-12-2006 10:47 PM
Change File size in MB instead of GB in properties of a File rachitar QnA (read only) 4 24-11-2005 09:46 AM
How to convert a VDV (*.vob) file in to VCD (*.dat) file Choto Cheeta QnA (read only) 2 17-09-2004 01:47 AM
- by gohan89
