13-06-2007, 11:46 PM
Is it becoz of cheap DVD?
A month ago I burn 2 DVDs.I have checked that DVDs after burn.they ware running fine.
When I opened today & try to copy them in HDD,first some files copied but after that they r unable to copy.
These DVDs r very rarely used and has no scratches.
why they r not copied. Is it becoz of cheap(Rs.12) DVDs.
This type of prob. happen only with DVDs never with CDs.
means I used cheap(rs.5/6) CDs before,burn them but never face this prob.
14-06-2007, 01:02 AM
Rebooting
Re: Is it becoz of cheap DVD?
I buy Lasertras DVD from Kolkata they cost Rs. 9 each
I Never burn more than 4.1 GB in one DVD, and I see DVDs burnt 6/8 months ago (that time DVD used to cost more but compair with big brands they were still cheap) still working fine and healthy
rebooting
ChotoCheeta.com
14-06-2007, 01:06 AM
Still Shining!
Keep your data limit within 4 - 4.5
Don't exceed that.
Nokia N86 8MP
14-06-2007, 01:11 AM
I am Optimus Prime
Cool...I didn't know that...I thought we can burn full 4.7GB as in CDs....like we fill it till 705MB!!
14-06-2007, 08:56 AM
hi friends When i check a 4.7 GB DVD(blank) then nero 6/7 says that it has only 4.38 GB free. I tried different brands but got the same result. Why is this so?
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
14-06-2007, 10:44 AM
Host4Cheap.org
9 Rs damn cheap  Here cheapeast is Navtech or Techcom for 12 Rs. But WTH i have 320GB Hardrive
http://www.host4cheap.org/
14-06-2007, 12:26 PM
Dreamweaver
Here Master 16x DVD is 12 Rs
14-06-2007, 12:42 PM
Bcoz Windows reads 4.7GB As 4.38
And
Near my home Amkette 16X DVD's are for 12Rs
14-06-2007, 02:24 PM
80% due to cheap DVDs. Sometimes this happens with me on CDs too. Also it may be because your DVD reader is dirty. Buy a Drive cleaner and then try copying again.
KDE on ArchLinux
14-06-2007, 02:40 PM
i can get writex at 12 rs but 9 is very cheap
14-06-2007, 06:49 PM
Well I hav burn both DVDs within 4.5GB
First one is abt 4.3 GB.If this dvd does not read then it might be that prob.
But 2nd dvd is just 2.1 GB burn.even not in multisesson.
Both dvds r scratchless.
so what's the real prob?
14-06-2007, 10:47 PM
Still Shining!
how much time did it take to write the DVD? If there is some DMA problem then the dvds written will be useless. I had experienced it many times.
Nokia N86 8MP
14-06-2007, 11:00 PM
Google Bot
even i use the cheap dvds.. Never faced ny such prob tho i fill them fully.. Try writing at 4x
14-06-2007, 11:02 PM
No DMA prob. they r running fine after burning.
now i think may be my DVD drive prob.
My drive is just replaced by company.
but other dvds havn't got this prob.
16-06-2007, 12:48 PM
Cool as a CUCUMBAR ! ! !
yes u r right ........ cant TRUST DVD ritting .........
cd ritting was much trustworthy .............
16-06-2007, 02:05 PM
also slow writting speed I keep 8X-12X
16-06-2007, 06:41 PM
Host4Cheap.org
Yes, Keep writing speeds low. Mine is always 4X
17-06-2007, 11:53 AM
U Can Write At The Speed Of 12x . And There Will Be No Problem
Here I Purchase Dvd's At The Cost Of 9 , Company == National
17-06-2007, 09:22 PM
#19 (permalink)
Just burn some more DVDs.nero say burning process completed successfully.
then i press next DVD comes out of drive,then i close the again to check the DVD running or not and... this dvd cant able to open??????????
I open the drive and closed it again,but prob. remains same.
On the next day(today) i try to open it and it opened without any prob.
I think restarting pc fix this prob.
So after burning each dvd i hav restart my pc to check the DVD.
why it doesnt open after burning.
17-06-2007, 09:42 PM
#20 (permalink)
Still Shining!
^^^How much Ram do you have? Its because windows pages its files in to the hard drive for allowing more RAM to nero. So after writing you can see that windows hangs and HD light stays on for a while. Explorer is struck somewhere, that's why the DVD doesn't open immediately after burning.
Nokia N86 8MP
17-06-2007, 09:51 PM
#21 (permalink)
I hav 512 mb ram
17-06-2007, 10:02 PM
#22 (permalink)
Still Shining!
512 should work fine. I have no probs.
That isn't a problem, I think. Instead of restarting, wait for 10-15 mins before inserting it again. From task manager shut down and restart explorer, and try.
Nokia N86 8MP
Search this Thread |
