Old 13-06-2007, 11:19 PM   #1 (permalink)
free world from money
Projjwal's Avatar
Default Seperate voice from song...???
Is there any way to seperate voice from song...?
I recently bulid a bandpass filter for mp3 songs . If the voice & music frequency range r different then it will split voice & music from song..
Pls help.........
Projjwal is offline
Old 13-06-2007, 11:47 PM   #2 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Default Re: Seperate voice from song...???
Try AV Music Morpher Gold
rakeshishere is offline
Old 14-06-2007, 01:07 AM   #3 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Try
http://www.hydrogenaudio.org/forums/...howtopic=17450
Center Cut DSP for Winamp
http://www.hydrogenaudio.org/forums/...howtopic=17661
foo_centercut: Center Cut DSP for foobar2000
Both are plugins and can do the job to some extent.
But doing this perfectly is impossible...though using some hardwares its possible...forget the perfect with softwares.
With Adobe Audition its also possible using filter named "Center Channel Extractor" in it.
Or
Audacity(Effect->Noise Removal) and filter out the voice,then load the file again and filter out the music.
http://audacity.sourceforge.net/help...=remove-vocals
But the sound will be distorted and is not perfect.
Another option:
You could try something like AnalogX's VocalRemover, which is free, however there is a simple caveat that goes with it (and pretty much all vocal removers). The vocals must be recorded equally in both channels (i.e. straight down the centre of the stereo mix), and the music must be well separated in the mix. If the vocals are down the centre, they won't be removed. If the music, or any part of it, is equally mixed in the left and right channels, it will also be removed.
One more option
get dBpoweramp Music Converter from http://www.dbpoweramp.com/dmc.htm
and install this plugin: http://www.dbpoweramp.com/bin/dBpoweramp-dMC-DSP.exe
Read more about this: http://www.dbpoweramp.com/dbpoweramp-dsp.htm
Last edited by navjotjsingh; 14-06-2007 at 01:07 AM. Reason: Automerged Doublepost
navjotjsingh is offline
Old 15-06-2007, 12:25 AM   #4 (permalink)
Projjwal's Avatar
Alls worked but not upto the mark.many many thax to u for thouse.So, the centre channel is responsible for the voice.U also told about Hardware solution . how it possible??
Projjwal is offline
Old 15-06-2007, 09:28 AM   #5 (permalink)
I am Optimus Prime
Sorry even I don't know about hardware solution. I just read somewhere.
Old 15-06-2007, 05:31 PM   #6 (permalink)
this tropic has been discussed many times and i dont know why some body doesnt make it sticky
any way the answer is virtual know
you can minimize voiceso that the voice is not heard...because of low pitch
but you cannot separate ,eliminate voice...
be who u r :
Saharika is offline
Old 15-06-2007, 09:21 PM   #7 (permalink)
CA50's Avatar
u can try X video converter to extract the audio or Virtual dub
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 16-06-2007, 08:45 AM   #8 (permalink)
HELP AND SUPPORT
@Projjwal
Also Try Yogan Vocal Remover
Old 17-06-2007, 07:28 PM   #9 (permalink)
Originally Posted by rakeshishere
@Projjwal
dont try..
i just tried and it is useless..useless download...
even the software itself says..
this TRIES to remove...
i tested on effect...in most of song
be who u r :
Saharika is offline
Old 17-06-2007, 08:18 PM   #10 (permalink)
lalam's Avatar
Don't think there's a software out there though that may achieve this like a numero uno.....Look for the acapella tracks instead use google......Sure u wouldn't find every song u ever want......I guess it takes some work to do this near perfection using some sound editing software.....Less said better ask some deejay lol who knows....Ha ha
lalam is offline
Does seperate domain name help? naveen_reloaded Chit-Chat 8 06-06-2007 04:40 PM
how to seperate voice in audio file ? assddd QnA (read only) 8 02-06-2007 04:36 PM
making midi of song with voice Saharika QnA (read only) 4 03-05-2007 07:49 PM
All-in-One or Seperate Printer and Scanner? jiteshbhimani Peripherals 3 17-09-2006 09:14 PM
How to seperate Voice from Songs .. krishnansurya QnA (read only) 15 16-02-2005 12:35 AM
- by gohan89
