13-06-2007, 03:13 PM
Unable to log in
Guys lately i am unable to log into any mail site or into orkut i hav a perfectly valid id the only way i access my mail account usin google talk i sign in through Gtalk and check my inbox.In orkut i am unable to log in and same prob wit yahoo
“I'd rather be hated for hated for who I am, than loved for who I am not.” -Kurt cobain
13-06-2007, 03:51 PM
TechTin.com
Re: Unable to log in
can U log through another PC??
Try another browsers IE,opera,Firefox..than try to login.
Plz post the result.
13-06-2007, 05:19 PM
Tried using diff browsers same prob.From other pcs i am able to log in.Though anti virus scans and antispyware scans on my comp show nothin.I am able to log into digit forum though
13-06-2007, 05:25 PM
TechTin.com
can I know wht error you get on your PC??
13-06-2007, 05:58 PM
No errors the page jus keeps on loading.I use a bb connection so cant blame the band width here
13-06-2007, 07:39 PM
Microsoft MVP
Open following file:
%windir%\System32\drivers\etc
Contents of this file will be as following:
# Copyright (c) 1993-2006 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
If its not like the above, then replace urs with the above mentioned.
13-06-2007, 07:47 PM
Nop the same file i am able to surf all other sites jus the logging in part esp in gmail and orkut BTW i am able to log into forums
13-06-2007, 07:58 PM
Microsoft MVP
R u able to log into ur Gmail account from following link:
m.gmail.com
13-06-2007, 08:28 PM
Yeh i was able to.But problems persist wit orkut
13-06-2007, 08:44 PM
Microsoft MVP
I think u don't hv Java installed in ur system. Install Java or JVM and ur problem will be solved!
14-06-2007, 10:21 PM
Nop i do hav java installed as i do get the login form.I was able to log in for the first few days the prob cropped now only.Gmail jus keeps on loadin if i directly enter my address thru the browser.I am able to log in using google talk and check my mail thru tat.But no such luck for orkut even after i enter my username and password it ju keeps asking for my password again and again and it is a valid password
Figured it out it works jus fine with my sunbelt kerio personal firewall disabled
Reason: Automerged Doublepost
14-06-2007, 10:23 PM
a_g = JPKN
adjust/disable COOKIE Control in the F/W.
ASUS K53SV SX520D + BF3
14-06-2007, 10:36 PM
Yeh tat was it unticked all filter cookies option did it
15-06-2007, 12:15 PM
Are you using any firewall. Some webmail accounts need tuning up settings of firewall for proper functioning.
18-06-2007, 12:14 PM
Cool as a CUCUMBAR ! ! !
clear all ur cookies & history .........
check if u have by mistakely BLOCKED these sites in ur BROWSER & FIREWALL ........
18-06-2007, 12:59 PM
Delete all your cookies
And stop blocking from Firewall and AV
Install latest JVM
Search this Thread |
