hi ppl i have airtel mo activated on my k750 when i use it as modem to browse the net i get window of connection to airtel link failed why is this so pls help methanks
1) Install the software from CD that comes with phone.
2) Connect the phone through USB cable and open a connection
3) Create a dial up connection.Go into yor control panel,then into internet options.Then go to connections and add.Create a dial up connection .
4) once everything is done, you will connect directly to the internet.
Go in control panel--phone moniter options--can U see sony ericssonk750 i
i get connecting sign in my mobile screen while dialing window appears on pc after sometime connection failed check internet settings or network problem on my mobile .
Reason: Automerged Doublepost
