Old 22-02-2005, 04:44 PM   #1 (permalink)
Default new pc -suggestion required
Hi!
I would like to pick up a pc with the follg spec ,i have sort of zeored on certain specs,would like your suggestions.Iam based in Chennai
AMD 64 3000+
ASUS K8NE- DELUXE OR MSI NEO PLATINIUM
(Can any of you guys based in Chennai suggest as to where i can get MSI boards,from the places i checked nobody seems to carry it)
GPU - Iam totally confused but my buget is 8k,this is where i need help
Transcend - 512mb(ddr 400)
Samsung 120GB
Samsung Monitor 793S (is this ok or any alternate)
lLogitech Wireless Optical Combo
Lite On 16x DVD Writer
Case (Iam lost againt,guess i need 400W power supply,will Antec fit in 3k Budget?)
Total buget 45K
Thanks guys await you response.
Hey should i wait for the budget to get any better deal than what is avilable now?
Muks
mukund1224 is offline
Old 22-02-2005, 06:52 PM   #2 (permalink)
Just Do It
Charley's Avatar
dude , chck prices at computermegabazar.com for deals.........
Charley is offline
Old 22-02-2005, 10:25 PM   #3 (permalink)
Default Re: new pc -suggestion required
Originally Posted by mukund1224
Hi!
AMD 64 3000+
Samsung 120GB
Total buget 45K
Muks
Make the following changes-
CPU -Try to get 3200 instead of 3000
GPU -9600pro or XT for 7 and 8.5k respectively (not sure about prices in chennai,must be higher than delhi)
HDD -Go for seagate
case- Lower model of Antec is available for arnd. 3k go for it
PSU- Antec SL 430 Watts is a good choice.
Antec Cabinet, P4 2.8 ghz (HT), Sony Dvd Rom, XFX 5600 U, MSi 875 Neo2, 80 GB Seagate Barracuda 7200 RPM, Creative SB live 5.1, Creative Inspire 4.1 4400, Corsair 512 MB DDR
Delpiero is offline
Old 22-02-2005, 10:36 PM   #4 (permalink)
u can check out lotus computers in ritchie street . he has low prices , but ask him to lower it much further . Try for seagates hdd with 7200 rpm or higher . regarding RAM , check which one has more warranty . i think kingston is a bit costlier , but they have 3 years warranty . For ur rig , get a good BRANDED , high capacity UPS . for dvd writer , check feb chip , they have a few dvd rw tested out . Case , if ur spending in that much , antec is good . try getting it directly from the antec guy . his address is in dig or chip and he is based in chennai . check that the case has extra fan provisions and some even have lcd display in front to show fan speed or temp (1 of them ) . another model is the zebronics lava , but service is BAD . Check most of ur components to see if they are MADE IN CHINA , try getting stuff made in taiwan or elsewhere .
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 23-02-2005, 03:56 PM   #5 (permalink)
Hi klinux
Thanks and let me start my hunt [/img]
Old 23-02-2005, 04:39 PM   #6 (permalink)
Hi klinux
- by gohan89
