Old 22-02-2005, 03:51 PM   #1 (permalink)
Default Formatting My HDD...??
Hi fraindz i've one problem
I don't know...
How Much Time I can Format My Harddisk.....?
Can ne problem occur after many time format it...?? :roll: :roll:
If you want the best, you have to vote for the best
V.I.P.U.L.:= Vigilant Individual Programmed for Ultimate Learning
vipul is offline
Old 22-02-2005, 04:31 PM   #2 (permalink)
It depends on the Type of Format.
If u quick format, thne not to worry, but in case of full format there is a limit around 1K you can format your HDD.
Kapil Wadhwa
hikapil@yahoo.com
http://www.flashwires.com
hikapil is offline
Old 22-02-2005, 04:48 PM   #3 (permalink)
Default Hi
Don't worry,
You can quick format ur hard disk, full format it many times but be careful while changing file system.
ganesh_dabhade is offline
Old 22-02-2005, 10:02 PM   #4 (permalink)
Just Do It
Charley's Avatar
hey, ive formatted the disk umteen times both quick and normal..... no problems here. ......... make sure that u have a bootable disk to get it up and kicking
Charley is offline
Old 22-02-2005, 11:46 PM   #5 (permalink)
enoonmai's Avatar
I dont think the question really matters as all high level formats just clear out the file tables and mark the space as free for the OS to use after reinitializing the tracks/sectors. However a low level format is something totally different and it should be used as sparingly as possible. And in fact, you would hardly need to do a LLF on the disk in any circumstance.
Playing FEAR XP/LSW2
enoonmai is offline
- by gohan89
