Old 12-06-2007, 08:34 AM   #1 (permalink)
Default what is the difference between different kind of ports ?
what means:
open port.
closed port.
listening port.
established port (i saw that while doing netstat command in cmd).
tcp and the other one(udf or something like that i think) port.
assddd is offline
Old 14-06-2007, 05:06 PM   #2 (permalink)
Default Re: what is the difference between different kind of ports ?
aargh dude what is ggole n wikipedia for
http://en.wikipedia.org/wiki/Port_scanning
To handle yourself, use your head; to handle others, use your heart.
sensationalboy is offline
Old 14-06-2007, 05:26 PM   #3 (permalink)
God of Mistakes...
Garbage's Avatar
Post Re: what is the difference between different kind of ports ?
Originally Posted by assddd
what means:
open port.
closed port.
listening port.
These are not perfect definitions, but can serve ur purpose
Open Ports means ports thru which another machine can talk with ur machine or vice-versa.
Closed ports means those ports which can't accept/transmit data.
Listening ports means ports which are ready to accept data.
Established ports means communication is going on thru those ports.
TCP/IP, UDP & others are Protocols.
Basically, protocols are the rules which DATA follows while transmitting.
I told u as simple as I can. Remember, all this is technically slight different.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 14-06-2007, 06:46 PM   #4 (permalink)
if i want to use a port for a bittorent client, i need to use listening port?
assddd is offline
Old 14-06-2007, 07:17 PM   #5 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Yes.
But you can manually open ports if you want.
Quiz_Master is offline
Old 14-06-2007, 09:58 PM   #6 (permalink)
God of Mistakes...
Garbage's Avatar
THIS may help you !!!
Garbage is offline
Old 15-06-2007, 07:27 PM   #7 (permalink)
i did netstat in cmd, saw a number of a port near Listening Port and i used it in Azureus but nothing happens and the test still says it is closed.
what does it mean ?
what to do ?
assddd is offline
Old 15-06-2007, 08:44 PM   #8 (permalink)
God of Mistakes...
Garbage's Avatar
most probably they are used by another program.
Try to open some ports manually & then try to connect thru them
Garbage is offline
is there any new kind of DOS hansraj QnA (read only) 8 17-02-2006 11:48 AM
kind of a gud idea KoRn QnA (read only) 11 10-02-2006 05:38 PM
what kind of problem is this? kamaal QnA (read only) 1 19-06-2005 02:32 PM
for your kind help-reg. kumarn_2004 QnA (read only) 1 24-01-2005 02:35 PM
- by gohan89
