Old 11-06-2007, 09:09 PM   #1 (permalink)
Alive Again...
satyamy's Avatar
Question Sitemap in XML.....?
Wht is site map
why it is always in XML
Wht is the use of it
can anybody tell me
I found this link for creating sitemap
http://search-dir.com/ror.php
satyamy is offline
Old 11-06-2007, 09:33 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Sitemap in XML.....?
http://en.wikipedia.org/wiki/Google_Sitemap
There are various Sitemaps generators and submiters for common scripts like IPB, PHPBB, vBulletin forums and blogs. Use is basically getting the site indexed properly.
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 11-06-2007, 09:36 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
but whts the use?
satyamy is offline
Old 13-06-2007, 12:51 PM   #4 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
sitemap = easy 2 navigate [if u r lost] & displays all links of ur site .........
u can create sitemap in dreamweaver 2 ..........
browse its help tuts ....... u will find it ............
ax3 is offline
Old 13-06-2007, 05:18 PM   #5 (permalink)
Host4Cheap.org
Originally Posted by satyamy
but whts the use?
Everything is written over here
Old 13-06-2007, 05:26 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
one good reason for having a sitemap for ur site is..SEO
ravi_9793 is offline
Old 13-06-2007, 06:13 PM   #7 (permalink)
Alive Again...
satyamy's Avatar
can u tell me any good site which uses sitemap?
how does it look?
satyamy is offline
Old 13-06-2007, 06:33 PM   #8 (permalink)
Host4Cheap.org
Looks same, sitemap is just a link of URLs for google to Index easily. The XML file you sumbit to Google is freuently updates and full of URLS for Google to index
Old 13-06-2007, 10:27 PM   #9 (permalink)
TechTin.com
ravi_9793's Avatar
how does it look?
I am using www.techhunt.org
And mine site has got PR 2 only in few months....I never submitted my this site to any search engine.
Old 13-06-2007, 10:40 PM   #10 (permalink)
Alive Again...
satyamy's Avatar
may be because of the number of visitors......
satyamy is offline
Old 13-06-2007, 10:49 PM   #11 (permalink)
The Unknown's Avatar
hey you are using drupal na?
@satyam,
sitemaps need not be always in XML.
See this HTML sitemap:
http://w3schools.com/html/tryit.asp?...ryhtml_areamap
KDE on ArchLinux
The Unknown is offline
Urgent: Google Sitemap Troubles tuXian Internet & WWW 2 30-12-2005 08:11 PM
Google Analytics- How to Create SiteMap Properly. abhinav Internet & WWW 2 02-12-2005 05:22 PM
- by gohan89
