Old 11-06-2007, 01:24 AM   #1 (permalink)
bizzare_blue's Avatar
Default DVD-Writing/Reading Problems
Two months back, I had to change my DVD-Writer as the older one got dysfunctional. I bought a new Sony DW-G120A writer. When I used this writer to read or write DVD's, it took too long to do so. Then, I got it tested on another machine and it worked perfectly there. Then, I changed the Data-cable but to no avail. Next, I changed my SMPS and got myself a new 400W iBall device. Earlier, I was using a 250W SMPS.
This time again, I am facing the same old problem....The only culprit left is the Motherboard...I want to know if it REALLY is a motherboard problem and will I have to change my motherboard?
Also, I thought I should mention this...off lately, my UPS has been acting very strange and its software sometimes shows "Estimated Battery Time" of around 40-50 minutes....I have an APC Back-UPS ES 500....and earlier it used to show estimated time of around 15 minutes with 100% charged battery....
I wanted to know if this might have to do something with the problem I mentioned earlier. Please...Please....Please help me with this one....waiting for a reply...
Bitten by the open-source bug...
bizzare_blue is offline
Old 11-06-2007, 01:34 AM   #2 (permalink)
CA50's Avatar
Default Re: DVD-Writing/Reading Problems
I Think It Is Dma Problem. Plz Check That .
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 12-06-2007, 09:45 PM   #3 (permalink)
How can I check the DMA settings?
Old 12-06-2007, 09:59 PM   #4 (permalink)
Still Shining!
Lucky_star's Avatar
Close your eyes and use this tool: DMA RESET
your problem will be solved.
Nokia N86 8MP
Lucky_star is offline
Old 14-06-2007, 09:04 AM   #5 (permalink)
CA50's Avatar
U can listen to Lucky star, or goto device manager 4m control panal>system>hardware>device manager. There double click onIDE ATA/ATAPI controllers , go to advanced settings and DMA is there...
HAPPY HUNTING
| Nokia 2700c |
CA50 is offline
Old 14-06-2007, 12:02 PM   #6 (permalink)
Smile Re: DVD-Writing/Reading Problems
thanx "CA50" and "Lucky Star".... I have successfully solved the problem as per ur directions....I had to upgrade DVD-RW's firmware for that...
Thank you very much...
cd not reading gofeddy Software Q&A 4 25-11-2006 08:18 PM
Confusion in reading/writing symbols! REY619 Hardware Q&A 8 28-07-2006 03:56 PM
MMC Reading problems... h_kunte Buying Advice 1 19-11-2005 12:18 PM
ISO Reading ilias QnA (read only) 9 07-04-2005 10:43 PM
CD Writing Problems shriekers QnA (read only) 5 09-12-2004 04:23 PM
- by gohan89
