Old 22-02-2005, 09:07 AM   #1 (permalink)
Default setting priority of a task in task manager
when i change the priority of a task from task manager(like setting to low or high)...i have to change it everytime i start that application or task again and again...
is there a way so that this can be made permanent so that everytime i run that application it starts with same priory in task manager...
zoom is offline
Old 22-02-2005, 09:12 AM   #2 (permalink)
kl_ravi's Avatar
1) Can you list out the programs which are taking lot of CPU usage...
2) Can you post a screenshot of the task manager here
to start with, you should not meddle with critical services like ddhelp, explorer, lsass, rpcss etc...
BTW welcome to the discussion group.
kl_ravi is offline
Old 22-02-2005, 09:18 AM   #3 (permalink)
kl_ravi's Avatar
If you want to speed up your computer.. follow these links to stop unwanted services from running automatically...
http://biokdd.informatics.indiana.ed..._services.html
http://www.blackviper.com/WinXP/servicecfg.htm
kl_ravi is offline
Old 22-02-2005, 11:25 PM   #4 (permalink)
enoonmai's Avatar
No, there is no way to start a program with a preset priority unless it happens to be a pure DOS program. The only way to change priority is via the Task Manager screen, and as far as Windows is concerned, all processes have equal Normal priorities unless specifically overridden by the user. Of course, make sure you don't set Realtime priorities for load intensive programs, otherwise you run the risk of locking up the system and crashing it.
Playing FEAR XP/LSW2
enoonmai is offline
Old 23-02-2005, 12:11 AM   #5 (permalink)
might help : http://www.winsite.com/bin/Info?20500000038543
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
- by gohan89
