Old 10-06-2007, 11:22 AM   #1 (permalink)
Default Infected .... :(
Everytime i restart my computer..a process named IEXPLORE.EXE starts in the background...When i kill this process it restarts again..i have scanned my computer with Avast & Spybot but nothing detected..this process is taking a lot of memory.
Please Help....
vineetrocks2005 is offline
Old 10-06-2007, 11:29 AM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: Infected .... :(
http://forum.theispguide.com/isp-ftopic3643.html
Third Eye is offline
Old 10-06-2007, 01:25 PM   #3 (permalink)
tried this...but no avail ???
Old 10-06-2007, 01:28 PM   #4 (permalink)
The Unknown's Avatar
Did you scan with updated avast and spybot?? Or it can be an adware too. Avast detects some adwares, but i don't know as i was a XP user but now i am an OSS guy.
KDE on ArchLinux
The Unknown is offline
Old 10-06-2007, 01:49 PM   #5 (permalink)
D i s t i n c t l y Ahead
saurabh kakkar's Avatar
Smile Re: Infected .... :(
Please Help....
buddy ur system is not infected with any virus IEXPLORE.EXE is the exe file for internet explorer 7 and it will start automatically when ur system starts.
u can use msconfig to disable it ( i dont know the exact method )
saurabh kakkar is offline
Old 10-06-2007, 02:09 PM   #6 (permalink)
How do you know that he has installed IE 7?
KDE on ArchLinux
Old 10-06-2007, 03:03 PM   #7 (permalink)
buddy i am using internet explore 7 for a while now and i know that IEXPLORER.EXE is its executable file . i think u r not an active user of I.E 7
Old 10-06-2007, 03:10 PM   #8 (permalink)
It is impossible for me as i am a non-windows user. Can't you see my signature and title saying "Linux"?
KDE on ArchLinux
Old 11-06-2007, 10:53 AM   #9 (permalink)
I am using IE 6 & i have scanned my computer with the updated versions of Avast & Spybot...& there is no entry for IEXPLORE.EXE in msconfig...
Please help me...???
Old 11-06-2007, 11:43 AM   #10 (permalink)
sorry buddy i had forgotten that IEXPLORER.EXE is ALSO the executable file for internet explorer 6 .
if u r having problem with IEXPLORER.EXE then u can try uninstalling it use control panel or follow the following link works on xp also
http://support.microsoft.com/kb/q293907/
OR
http://support.microsoft.com/support.../Q293/9/07.ASP
after u have uninstalled u can try firefox mozilla link for u r internet access
www.mozilla.org/download.html
Old 11-06-2007, 02:57 PM   #11 (permalink)
dear just uninstall the iE and again reinstall it by the windows cd from the add remove windows components
pravesh_4766 is offline
Old 11-06-2007, 04:42 PM   #12 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
uncheck or disable it : check auto updates in options .................
ax3 is offline
Old 11-06-2007, 06:07 PM   #13 (permalink)
Distinguished Member
anandk's Avatar
check its location.
the file IEXPLORE.exe shud be in C:\Program Files\Internet Explorer
if not; its malware !
get it checked at http://www.virustotal.com/en/virustotalf.html
if it turns out to be malware;
use deletedoctor from www.diskcleaners.com to delete it on reboot.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Please Help .. I am Infected. MambaXL Software Q&A 10 13-02-2007 01:48 PM
svchost.exe infected!!!!!! shashank_digitreader Software Q&A 19 20-01-2007 12:11 PM
Infected by virus Suhas M Software Q&A 3 03-01-2007 11:13 PM
help me my pc is infected bholu Software Q&A 11 22-01-2006 11:00 AM
infected by w95.cih HELP!!! paul_007 QnA (read only) 9 28-02-2005 01:42 PM
- by gohan89
