10-06-2007, 03:55 AM
how to find open ports ?
i know that i need to write in cmd netstat -an
but when i try to check with Azureus client if those ports are open, it says they are closed.
please help, how can i find open ports ?
listening ports means ports that are in use ?
10-06-2007, 02:03 PM
D i s t i n c t l y Ahead
Re: how to find open ports ?
buddy no hacking help in this forum u can google ur question and can find the answer
AFAIK finding potrs which r open is very difficult cos from thousands of active ports only one or two opens and that to for very small period of time .
someone plz correct me if i am wrong
10-06-2007, 02:14 PM
use Dtask manager
10-06-2007, 07:38 PM
God of Mistakes...
dear, who told u that only hackers wanna know open ports ??
& u can get answers of nearly all questions from google, then why these forums are for??
Who says that it's difficult...??? Now a days u don't have to do it manually.
U can get port scanner HERE
10-06-2007, 08:11 PM
NP : Crysis
^^nice reply
10-06-2007, 09:26 PM
thanks for correcting me But i wana know for what else purpose u wana know open ports ?
AFAIK these forum is for sharing u r knowledge u r experience lerning from some one which google cant lol
10-06-2007, 10:35 PM
God of Mistakes...
Knowing open ports u can investigate if u have trojan horse or malware installed.
Most of them open specific ports to communicate with their client softwares.
11-06-2007, 01:26 AM
i said i need it for Azureus.
these programs are completely secured ?
Reason: Automerged Doublepost
11-06-2007, 11:20 AM
* Teh Flirt King *
Ofcourse they are buddy. They are meant specially for Network Administrator.
I am guessing you want to check opened ports so u can set azures to use that port. Am I right?
Well her is a suggestion, you can manually open ports in your firewall and router (modem.) Do this. Its better if open ports ourselves and then set Azures or utorrent to use that port.
@saurabh kakkar
You need to open port if you want to download with full potential on utorrent or azures.
11-06-2007, 10:54 PM
God of Mistakes...
unless & until u have downloaded them from secure source !
12-06-2007, 07:36 AM
@saurabh kakkar
i prefer not to mess with my router (my brother wont let me, and i cant make him open ports for me).
12-06-2007, 07:43 AM
Commander in Chief
To forward ports on a router, you got only 2 ways. Manual or UPnP if it supports it. Else forget torrents
Harsh J
www.harshj.com
12-06-2007, 08:25 AM
i used Nmap and i found an open port but the test i did with azureus said it is closed.
is it open or closed ?
14-06-2007, 06:41 PM
bump!
16-06-2007, 03:45 AM
a port is opened and i used it in azureus, the test in that program says its closed.
anyway, now that i put it there will my download be faster (im downloading torrents with 5 - 10 seeders) ?
my downloads should be much faster ?
what do you think my max download speed should be ?
i have 2.5 MB adsl.
16-06-2007, 08:02 AM
Commander in Chief
5-10 seeders would hardly give more than 10KBps momentary speeds ..
Harsh J
www.harshj.com
16-06-2007, 08:27 PM
BW Waster Certified
Location: Latitude: 22°38'30.96"N, Longitude: 88°25'52.26"E
@assddd : You can go here " https://www.grc.com/x/portprobe=xxxx".
Replace xxxx with a port number of your choice and check again...if it is open then use it..else try try again...and you will definitely succeed..
P4 1.70 GHz | Asus P4P800-VM | 1.5GB Transcend DDR-400| XFX 6600GT 256MB GDDR3 AGP | Seagate 320GB SATA 3Gb/s | Asus DVD Writer | CoolerMaster eXtreme Power 600W
04-04-2009, 04:40 AM
Hi Saurabh
you are 110% wrong about it, finding open port is not hacking, it is actually prevent for being hacked. so please practice b4 u preach.
Thanks
Jo
Search this Thread |
