Old 09-06-2007, 04:49 PM   #1 (permalink)
~[::BOoYaKa::]~
Unhappy Urgent help needed!!How to find Number of distinct elements in an array??
There is a problem I am stuck at, from yesterday. Using any loop(while, do...while, for), how to find the number of distinct elements in an array?
For example, if an array "a[5]" contains 1, 2, 1, 3, 2 then the number of distinct elements is 3. U can use if statement too.
The number of elements is known and stored in a variable "i".
Please someone help, its really urgent!!!
Thanx!
[::Eddie n Benoit Live Forever::]
REY619 is offline
Old 09-06-2007, 06:18 PM   #2 (permalink)
ashfame's Avatar
Default Re: Urgent help needed!!How to find Number of distinct elements in an array??
Thanx!
Dude do dis (m givin da code for C / C++)((I donno any other language))
int arr[100]; (tak acc to ur requirements)
int count=0;
for (int i=1;i<100;i++)
{flag=1;
for (int j=i;j>=0;j--)
if (arr[j]==arr[i-1])
{ flag=0; }
if (flag==1)
{ counter++; }
I think dat wil do!
if ya face any problem, lemme knw
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 09-06-2007, 06:58 PM   #3 (permalink)
Default Re: Urgent help needed!!How to find Number of distinct elements??
Or you could sort and store them and compare two consecutive elements only. While basic sort will require more computation than above algorithm, you can get faster results with efficient sorting algorithms...
Arun
sakumar79 is offline
Old 09-06-2007, 07:29 PM   #4 (permalink)
ashfame's Avatar
Arun
I agree that efficient sorting algorithms might perform better but what if the case is like holding values for a group in serial (for example: holding marks of students). In that case you cant even think of sorting the elements of array!
Anyways you also put forward a good logic!
Great!!
ashfame is offline
Old 09-06-2007, 07:44 PM   #5 (permalink)
In case sorting the array will mess up the data you hold, store the sorted array in another variable and process that variable...
Arun
Old 09-06-2007, 11:03 PM   #6 (permalink)
ashfame's Avatar
Arun
dude!
consider the memory limitations, just for a step you will create a new array!
thats nt gud!
ashfame is offline
Old 10-06-2007, 05:39 AM   #7 (permalink)
It will depend on the actual requirement of the software... And the discretion of the programmer... whether to add to the memory requirement or to get slightly faster results...
Arun
Old 10-06-2007, 07:10 PM   #8 (permalink)
~[::BOoYaKa::]~
THANKS a ton People!!
REY619 is offline
How To Find Total Number of Websites? muralikrishnan QnA (read only) 5 21-06-2006 12:46 PM
Code to find Number of command buttons sid_b6505 QnA (read only) 3 06-12-2005 06:19 PM
Code to find number of command buttons sid_b6505 Tutorials 1 04-12-2005 09:34 PM
How to find phone number of a friend in yahoo messenger robogeek Mobiles and Tablets 2 17-11-2005 09:47 PM
- by gohan89
