Old 21-02-2005, 06:32 PM   #1 (permalink)
Just Do It
Charley's Avatar
Default I cant play CD-R's in my CDRom, can play CD's , why
I've an 8x CDRom which is an old one but i can play movie Cds, audio CD's on it but cant play CDR's. or CDRW's , what is the reason for it.....
Charley is offline
Old 21-02-2005, 10:59 PM   #2 (permalink)
enoonmai's Avatar
Check the drive using Nero InfoTool to see if the drive supports reading these discs in the first place. You're the only guy I know who's using an 8x CDROM.
Playing FEAR XP/LSW2
enoonmai is offline
Old 22-02-2005, 02:18 PM   #3 (permalink)
Just Do It
Charley's Avatar
I have to upgrade my system to a new one , basically I use it for home purpose so havent thought of getting a new 1.. But the other componennts are upgraded freqntly....
Where do i get the Nero Info Tool from?
Tks....
Charley is offline
Old 22-02-2005, 04:23 PM   #4 (permalink)
enoonmai's Avatar
You can get Nero InfoTool by either installing the Nero Burning ROM demo included on many of the Digit CDs or you can always download them from here:
Nero InfoTool v3.61
Website:
http://www.pcworld.com/downloads/fil...d,22911,00.asp
enoonmai is offline
Old 22-02-2005, 05:28 PM   #5 (permalink)
Just Do It
Charley's Avatar
This is the scan result i got on nero......
Serial Number;Drive;Firmware;Transfer Rate - Average;Transfer Rate - Start;Transfer Rate - End;Random Seek Time;1/3 Seek Time;Full Seek Time;1 X CPU Usage;2 X CPU Usage;4 X CPU Usage;8 X CPU Usage;Burst rate;Spin Up Time;Spin Down Time;Load Time;Eject Time;Recognition Time
?;MATSHITACD-ROM CR-583 ;107J;8.02x;7.99x;8.04x;77 ms;86 ms;139 ms;7 %;13 %;26 %;54 %;2458 KB/sec;4.07 sec;1.49 sec;1.57 sec;2.97 sec;13.23 sec
Wht does it mean?
Charley is offline
Old 22-02-2005, 08:15 PM   #6 (permalink)
enoonmai's Avatar
LOL, the PC World site lists the file as InfoTool but downloads another Nero Toolkit program called "CDSpeed" .
Download the Nero InfoTool from here:
http://www.cdspeed2000.com/files/NeroInfoTool_227.zip
and then once it finishes the diagnostic, select your CDROM and you will be able to see checkmarks on CDR. CDRW, etc. if it supports it.
Like so,
enoonmai is offline
- by gohan89
