Re: cant play test drive unlimited.
Carbon? I have played and completed it in a X200. And NFS MW doesn't need any requirements. Just 256 MB ram is necessary. I will be getting this game(TD unlimited) in probably 2 days. I will surely try it out on the D101GGC and will say you what I did.
As for now, You can try this: Right click on the file and goto properties. In the compatibility list, disable the visual themes and advanced text services.
Then before playing, shut down all the unnecessary program and the antivirus too. Then play it.
Nokia N86 8MP
