I hv got the iso format of GEEXBOX media player which i got in digit cd/dvd. I can use it after burning it to a cd and booting 4m it.
But the file size is 2 small. Is there any way by which i can create a cd/dvd which will contain other datas and is also bootable
__________________ | A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
why dont you mount it on a virtual drive and install it and use it instead of burning???
legolas.
