Re: How to backup MMC using PC Suite??
use da default Nokia content copier...
or use Fexplorer, (or somethin) similar on ur fone and copy the folder "system" to the root directory(or to any other visible folder) and then copy it using PC suite as the copied one wud be visible now!
C2D E8400, MSI P45 Neo-F, Sapphire HD4850, Dell 2409W, OCZ 2*1GB RAM + 1*2GB Transcend + 1*1GB Transcend , Seagate 1TB + 2*Seagate 80GB, 600W SMPS, APC 600VA, Creative EP630, Sennheiser HD202 :)
