Old 21-02-2005, 02:47 PM   #1 (permalink)
Default How I Get My MBR back...?
I remove all entries on my MBR Via one program in c
But Now I can't able to load any os
now What To do...???
Plese Help me Fast..........plese
If you want the best, you have to vote for the best
V.I.P.U.L.:= Vigilant Individual Programmed for Ultimate Learning
vipul is offline
Old 21-02-2005, 04:04 PM   #2 (permalink)
enoonmai's Avatar
LOL, I'd love to know what you did in C that erased the MBR.
Anyway, if you're running Windows 9x/ME, just boot the computer using the startup disk/install CD and in command prompt just type :
fdisk /mbr
That will recreate the MBR for you and you will be able to boot back into Windows.
If you're using Windows 2000/XP, boot using the Install CD, press R to enter the Recovery Console and type:
fixmbr
and follow the instructions.
Playing FEAR XP/LSW2
enoonmai is offline
Old 21-02-2005, 04:23 PM   #3 (permalink)
http://forums.pcquest.com/forum/viewtopic.php?t=1271
http://www.thinkdigit.com/forum/viewtopic.php?t=13783
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 21-02-2005, 04:58 PM   #4 (permalink)
That one is kool but dont try anoher nasty c programs.
Lovedeep Wadhwa
cheetah is offline
Old 22-02-2005, 01:14 AM   #5 (permalink)
any way can u post the program which could erase the MBR
Stay cool always!!!
cool_techie is offline
Old 22-02-2005, 07:44 AM   #6 (permalink)
Let the music play.....
djmykey's Avatar
Yeah I want that program. Does it run on any pc or it needs c to be installed first. Pls reply man we need a lot of such proggies.
djmykey is offline
Old 22-02-2005, 08:22 AM   #7 (permalink)
@vipul : if u created the program , distribute it under GPL with source
klinux is offline
Old 22-02-2005, 01:50 PM   #8 (permalink)
Try HDkiller to make harddisk unsusable.
Very famous program.
Try at ur own disk.
Find it here http://www.vw.vccs.edu/bussci/SUMMER...t248/tools.htm
Lovedeep Wadhwa
cheetah is offline
Old 22-02-2005, 02:02 PM   #9 (permalink)
Hey All
I Remove My MBR via A copyboot.c program which is used for creating bootable floppy but i just change the address floppy to my hda and this problem is occured.....
But Now It Is repaired ...
ok...
Thankx All Lot.....
vipul is offline
- by gohan89
