Old 08-06-2007, 12:43 PM   #1 (permalink)
Default Setting Virtual Machine ?
Can anyone help me in setting & running a microsoft virtual machine 2007.
I got XP, and want to install 98 and vista in virtual machine.
PC Config.
1 GB RAM , 3 GHZ D Processor
guru is offline
Old 08-06-2007, 01:20 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Setting Virtual Machine ?
Download Microsoft VPC from here, http://www.microsoft.com/windows/pro...c/default.mspx
now if u have 32bit Windows XP then download the x86 and if u have 64bit Windows XP then download the x64 version !!!
Install it, pretty simple installation !!!
Now Running it... OK...
I belive u have Intel PD processor, but there are many models running at 3GHz http://www.intel.com/products/proces.../pentium_d.htm which one of it ?? if u have 930 then u have the Intel VT which is gr8 for Virtualization...
So if u have 930 and supported Motherboard, then go to BIOS and turn on the VT settings !!!!
Now with Virtual PC, Start the applciation... !!! for the 1st time it may ask u to Create new Virtual PC, cancle that...
Now at the VPC window Click File >> Option
Now there, Turn on the Hardware Virtualization (If available) !!!
Now, Next is Creatting one New Virtual Mechine !!
Click New, one wizered will come up, there Select Create a new Vurtual Machine !!
Now Click Next to Select a Location and name the Machine !!! Note By default it will save in My ducuments, which u should avoide as it will eat a lot on HDD space, so browse and select a place where u want it to be, and name it, in my case I name it Win98SE.....
Click Next and select the OS, Windows 98 !!!!
Now by default windows will arrange only 64 MB of RAM for Windows 98 SE now u can adjust that, as u have 1GB i suggest put 128MB or more of the Windows 98 SE
But if u will be running multiple VPC OS at a time then may be u can select less that too, how ever it is adjustable at any later stage !!
Click Next to Create a new Virtual HDD
Now here at Selecting ammount, it doesnt matter how much u select as VPC will only show that ammount but it will not alocate any pre-occupide space... so I selected 15GB, Note, Windows 98 will use FAT 32 which has a limitation of 32GB partition MAX !!!
So Click Next to Finish it....
Now in VPC window u will have new machine Win98SE... Highlight it and click settings, now here Turn on the Virtuallization and play with any settings if u need !!!
So, now Just Select the Mechine and Click Start !!! keep the Windows 98 Installation CD ROM in the CD Drive of ur computer !!
Now at VPC running window, Click the CD Menu and from there ask it to use Physical Drive x: and click action and Ctrl+alt+del, now you would see VPC is booting from Windows 98 CD....
from now on its just like any othyer windows 98 installation !!
TO use full screem use Right ALT + Enter note, with VPC by default, the Right ALT Key is for ur HOST OS... !!!
Now after you have completed the installation u may feel very slagish Mouse movement in side the VPC, so, Click Action and then Install or Update Virtual Machine Add ins
now u r done...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 08-06-2007, 01:54 PM   #3 (permalink)
Where can i find if it's So if i have 930 , and where in BIOS i can turn on the VT settings.
I have intel 945 mother board.
And also Hardware Virtualization option is not available.
Do i need ISO images to install or my cd drive will work in it ?
I have XP (NTFS) installed on my machine.
guru is offline
Old 08-06-2007, 01:57 PM   #4 (permalink)
Rebooting
See even if u dont have VT u could easily run VPC, but with VT it runs really smoth and better !!
how ever to know more about ur Processor, download CPU-Z, run the EXE to get complete info about the system u r running
Note, some AVS may detect CPU Z as harmfull object while running as it comunicates with BIOS, so keep the AVS off when running it
http://www.cpuid.com/cpuz.php
rebooting
ChotoCheeta.com
Old 08-06-2007, 01:59 PM   #5 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
WOW! Saurav...u little Devil
Which Screen Capture u use, seem to be so fast
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 08-06-2007, 02:03 PM   #6 (permalink)
Rebooting
err... Just Windows Print Screen and with ALTR+CTRL to capture the present window rather than the whole screen
rebooting
ChotoCheeta.com
Old 08-06-2007, 02:06 PM   #7 (permalink)
Host4Cheap.org
Thanks didnt knew that shortCut
Old 08-06-2007, 02:08 PM   #8 (permalink)
Rebooting
Welcome
I am Glad to help
rebooting
ChotoCheeta.com
Old 08-06-2007, 03:33 PM   #9 (permalink)
guru is offline
Old 08-06-2007, 05:39 PM   #10 (permalink)
Rebooting
@guru
Both of ur question's I have already answered,
In reply I wrote,
I wrote,
and it will work with ISO too,
Not an issue as Virtual HDD would b in FAT or FAT32 format !!!
rebooting
ChotoCheeta.com
Old 09-06-2007, 12:40 AM   #11 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Alt+Print Screen is enough! No need for Ctrl
kalpik is offline
Old 15-06-2007, 06:33 PM   #12 (permalink)
Ok , I installed VMware 5.5 and running vista home premium.
But Internet is not working. I have an Airtel connection, with login directly from my modem.
( As I am using Intel Board, How can i install drivers , as it says no intel board found ?)
And is it possible to move/copy files between your host and virtual machine.
guru is offline
Old 16-06-2007, 10:28 AM   #13 (permalink)
Host4Cheap.org
Edit Virtual Machine and EDIT Ethernet. Use NAT to share connection. Add HDD to share physical HDD
Old 16-06-2007, 05:14 PM   #14 (permalink)
But the Drivers are not installed, so how can i install the drivers.
guru is offline
Old 16-06-2007, 06:43 PM   #15 (permalink)
Host4Cheap.org
Which Drivers ? Since its a Virtual Machine...VMWare will come with its own
Will Serious Sam 2 run on my machine? bukaida Gamerz 1 15-11-2006 01:10 PM
Setting up IM??? prankie Mobiles and Tablets 7 19-05-2006 10:42 PM
ASP.NET Machine A... gambit QnA (read only) 1 17-07-2005 05:40 AM
Virtual memory setting Alive_Hunter Open Source 6 26-05-2005 02:07 PM
- by gohan89
