Old 21-02-2005, 02:25 PM   #1 (permalink)
Photoshopgyan.co.cc
Default how to get more of my floppy
Hi friends!
someone tells me that we can get more space on floppy by formatting it by a software. but i don't know that software. if u know that pls tell me.......
jitu_mania
[/b]
jitu_mania is offline
Old 21-02-2005, 02:45 PM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Haha, who told you so? U get a CD or a DVD man!
drgrudge is offline
Old 21-02-2005, 02:49 PM   #3 (permalink)
Laptoping
Sourabh's Avatar
well its true tht one can increase the capacity of the fdd
google for more info
Sourabh is offline
Old 21-02-2005, 03:03 PM   #4 (permalink)
drgrudge's Avatar
Hmm, i dint know abt that! Sorry guys! Well, in any case i wont be interested for a floopy disk thing!
drgrudge is offline
Old 21-02-2005, 03:23 PM   #5 (permalink)
enoonmai's Avatar
True, such software exist, but all they do is throw in a fre more kilobytes, and you also need the same software at the other place where you're taking the disk to, or else you run the risk of a not being to read it. The last I checked, all these softwares were non-standard. Technically, you can even use a Track 0 bad floppy too, if both source and destination use the same software.
Playing FEAR XP/LSW2
enoonmai is offline
Old 21-02-2005, 04:12 PM   #6 (permalink)
Back From Deathstar
Darthvader's Avatar
DUde use the drive space 3 in windows for compression
Darthvader is offline
Old 21-02-2005, 04:53 PM   #7 (permalink)
swatkat's Avatar
Windows has it's own Disk Compression tool called DriveSpace, u can use it...
but disk compression is not recommended...
http://swatrant.blogspot.com/
swatkat is offline
Old 21-02-2005, 04:58 PM   #8 (permalink)
Ethan_Hunt's Avatar
Drive Space 3 extends the Floppy Size to 2.56 MB or sometin like that.....Its dam simple Just Got Start-Programs-Accessories-System tools-Drive Space and Select ur Formated floppy drive and In the Drive menu select Compress...and Voilla ur done 8)
Ethan_Hunt is offline
Old 21-02-2005, 05:02 PM   #9 (permalink)
Laptoping
Sourabh's Avatar
lolzz
i thot of doing it again after first trying it a couple of time 2-3 yrs ago
went to System Tools> Drive space and heck then relaized i dun have a floppy disk drive 8)
Sourabh is offline
Old 21-02-2005, 05:07 PM   #10 (permalink)
compression?????
Lovedeep Wadhwa
cheetah is offline
Old 21-02-2005, 05:17 PM   #11 (permalink)
enoonmai's Avatar
But technically, DriveSpace3 doesn't really "extend" the capacity of your floppy disc. It just compresses the data into a CVF and then migrates it to the host drive, and I thought it wasn't really recommended to use it. The best thing to do is to zip/rar/cab any file you want and then copy to the disk. At least with zip/rar, if the file does conk up, it can at least be fixed.
enoonmai is offline
Old 22-02-2005, 10:16 PM   #12 (permalink)
Back From Deathstar
Darthvader's Avatar
HEy at least it gives the double the space of a floppy
Old 22-02-2005, 10:23 PM   #13 (permalink)
u have 2.88 mb floppies in the market now . those might help
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 22-02-2005, 10:51 PM   #14 (permalink)
NikhilVerma's Avatar
Don't you guys know about Alkonost MaxFormat !!!
It increases the size of a FDD to 1.72 MB without compression just by changing the file system...
NikhilVerma is offline
Old 22-02-2005, 11:41 PM   #15 (permalink)
kurious : like someone said , why use floppies anyway ??? they dont last that long at all . really irritating when u carry data a long way , just to get disk read error . if ur using floppies for boot disks or disk managers , just make a bootable image outta the floppy and make a bootable cd outta it . works gr8
klinux is offline
Old 23-02-2005, 09:33 AM   #16 (permalink)
kl_ravi's Avatar
HD Copy 2.0a does a good job
HD-COPY - Fast diskette copier and high capacity formatter.
[updated 2004-08-07]
From the docs...
HD-COPY is the fastest copy-program I know (and I know many) --- there's definitely no faster one. You can also use it to format disks at various formats (from 720 Kb to 1.764 Mb in this version of HD-COPY), which is faster than DOS' FORMAT and produce s less errors.
The following DD formats are supported:
* 320 Kb, 360 Kb, 720 Kb; "special" DD formats: 400 Kb, 800 Kb, 820 Kb and similar
The following HD formats are supported:
* 5 1/4 inch drives: 1.2 Mb, 1.44 Mb, 1.48 Mb and similar
* 3 1/2 inch drives: 1.2 Mb, 1.44 Mb, 1.48 Mb, 1.72 Mb and similar
Note: To use non-standard disks (i.e. 5 1/4 disks with more than 1.2 Mb or 3 1/2 disks with more than 1.44 Mb) outside HD-COPY, you have to install a TSR program like FDREAD (included), because the DOS/BIOS doesn't like disks with an unusual number of s ectors. HD-COPY itself doesn't need FDREAD, since it has its own routines to handle special formats.
Author: Oliver Fromme (1995) Germany. Cardware.
kl_ravi is offline
Old 23-02-2005, 05:31 PM   #17 (permalink)
SmartFormat 2.1
this is one of the program u wanna go for.
& it is of only 22kb
U can find it here :
http://members.tripod.com/ieeecrce/i...ons99/tformat/
pranav_cool is offline
- by gohan89
