Old 21-02-2005, 12:34 PM   #1 (permalink)
Default Long horn ,got my pc crushed
Guys had a problem with longhorn . after installation i had to set my pc to a restore point i was using sp2 that time
vijaythefool is offline
Old 21-02-2005, 01:49 PM   #2 (permalink)
club_pranay's Avatar
did u used the transformation pack?
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 21-02-2005, 02:34 PM   #3 (permalink)
im pretty sure he did
i dun think sp2 is available for longhorn yet
vijay dude be more clear
and whats the problem ?
u havent mentioned anything but that u installed LHTP and u set a restore point after installation
whats wrong ?
crushed ? u mean CRASHED?
damn dude be more clear
anyways u need a bootable disc or a bootable floppy
i suggest gettin a friend to make bart's PE disk for u
boot from it and replace all system files
u can also do this from ur winxp bootable cd
goto the recovery console and type in sfc /scannow
also if ur able to boot into windows but dun see anything but the wallpaper
u can press ctrl+alt+del to bring up the task manager
and then from file=> new task(run)
type in sfc /scannow and press enter
ull be prompted to enter ur win xp installation cd
3 solutions .. one problem ... in reverse order of preference
take ur pick buddy
No Mercy, No Limits.
theraven is offline
Old 22-02-2005, 01:43 PM   #4 (permalink)
abt the pc :
i am using win xp professional and i have installed sp2
i applied long horn , i needed to uninstall and found there was no uninstall option
so returned to safe mode and un installed as said in the long horn
installed for the second time and need came to uninstall as the entire desktop and all the contents turned black . went to the safe mode
but this time as soon as i entered the safe mode pc began to set a restore point
Old 22-02-2005, 10:16 PM   #5 (permalink)
lh
harishkumar is offline
Old 23-02-2005, 09:10 AM   #6 (permalink)
thank god!! some of the mods advised me to create a restore point before installation of LH Transformation Pack!! it made my work a loe easier!!
and thanx Mr harishkumar for your first post
Old 23-02-2005, 01:13 PM   #7 (permalink)
can anyone tell me how to uninstall LHTP
can you suggest tools to overclock.My configuration is
P4 2.00Ghz Intel D845GVSR 128Mb DDR266Mhz
Old 23-02-2005, 04:16 PM   #8 (permalink)
enoonmai's Avatar
Just run the install program again and choose the Uninstall option from the window that opens.
And somebody correct me if I am wrong, but I dont think the Intel D845GVSR board can be overclocked.
Playing FEAR XP/LSW2
enoonmai is offline
Old 23-02-2005, 08:10 PM   #9 (permalink)
U cant uninstall lonh horn like u said
this is what i ve explained int he post !
u have to uninstall frm the safe mode
Old 23-02-2005, 10:34 PM   #10 (permalink)
enoonmai's Avatar
Now that's how *you* couldn't uninstall. But otherwise that's the normal, safe way to uninstall LHTP. And I dont think harish is having the same problem as you.
enoonmai is offline
Old 25-02-2005, 01:37 AM   #11 (permalink)
Wire muncher!
infra_red_dude's Avatar
longhorn transform pack has lotsa woes.....it doesnt uninstall all files completely some files (like explorer.exe and files which are in use) dun get uninstalled and sp2 cant be applied until you haf a pure microsoft kernel...
i had d same prob...tried everything....coz everything was messed up.....finally formatted ma hdd and did a fresh install of sp2..will stay away from LHTP now....!!!
infra_red_dude is offline
Old 25-02-2005, 10:47 AM   #12 (permalink)
I am told its gonna be a real amazing os !
Old 25-02-2005, 10:52 AM   #13 (permalink)
And amazingly costly >= Rs 10,000/-
**** happens
pradeep_chauhan is offline
Old 25-02-2005, 04:34 PM   #14 (permalink)
godsownman's Avatar
Longhorn will be a good OS but the transformation apck is not so good so wait till 2006-2007 when it will be officially released by Microsoft.
Dont try the transformation pack they are not worth the try . :d
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 25-02-2005, 04:37 PM   #15 (permalink)
godsownman's Avatar
All the people i know are repenting that they tried that pack at some stage i also wanted to try it but I kept away after I read on the net and say the rating and people's recommendations .
Best is to AVOID !
Sorry for posting again i forgot to say this
Old 25-02-2005, 04:37 PM   #16 (permalink)
godsownman's Avatar
Best is to AVOID !
