Old 07-06-2007, 04:43 PM   #1 (permalink)
Question Difference Between OEM and Full
There is any difference between OEM and Full Manual Softwares. Why the companies makes a OEM Softwares. The features of Full Manual is disable on OEM ?.
http://www.miraclesoftware.in
Authorized Software Distributor - Online Software Shopping
boosters is offline
Old 07-06-2007, 06:40 PM   #2 (permalink)
Default Re: Difference Between OEM and Full
I think it varies from software to software... Many limitations often are in upgradeability of license,etc but most features are generally available in OEM versions...
Arun
sakumar79 is offline
Old 11-06-2007, 12:24 PM   #3 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
many features r disabled in oem sofwares ......... they r almost like trial version`s bt without TIME BOMB or limit .........
ax3 is offline
Old 11-06-2007, 04:18 PM   #4 (permalink)
can you please give me the comparison chart between OEM and Full
boosters is offline
Old 11-06-2007, 10:58 PM   #5 (permalink)
God of Mistakes...
Garbage's Avatar
I think that OEM versions are given for NEW computers. means with new computers
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 12-06-2007, 11:05 AM   #6 (permalink)
actually oem is distributed with hardware and full is purchased manually. Oem and full both are full.
abhijangda is offline
Old 12-06-2007, 11:20 AM   #7 (permalink)
Cool G5's Avatar
Post Re: Difference Between OEM and Full
The differences are:
OEM software typically does not include the colorful packaging and manuals that are found in retail version and support may not be provided by the publisher. However, OEM version is identical in functionality as retail software and is legally licensed if purchased with a hardware component. Almost all PC component and software vendors make two versions of the same product based on a difference in the distribution channels. One is the retail boxed products sold mainly through retailers. The second one is the OEM products which are sold mainly to system builders, such as Compaq and Dell (the OEMs). These bulk-pack products do not have fancy packaging materials and are often produced in much higher volume, both of which result in much lower prices.
Cool G5 is offline
Old 12-06-2007, 11:59 AM   #8 (permalink)
kumarmohit's Avatar
Actually using the term Full is a misnomer here, It is the retail version and OEM, version. Even an OEM is not a trial version either, sure it can be feature stripped like in case of nero or some apps that come with digital cameras and scanners.
kumarmohit is offline
Old 12-06-2007, 01:20 PM   #9 (permalink)
Rebooting
Choto Cheeta's Avatar
As already said,
OEM / Full / Volume these are all Licensing terms, the basic software in Most cases are same, though the Activation or Authentication method in few case are different, but never the less, the software core and interface are same !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 12-06-2007, 05:38 PM   #10 (permalink)
God of Mistakes...
Garbage's Avatar
can anyone tell me full form of OEM ??
Garbage is offline
Old 12-06-2007, 06:37 PM   #11 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Original equipment manufacturer - just google it next time. Takes a sec
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 14-06-2007, 01:09 PM   #12 (permalink)
cooldip10's Avatar
Hey guys I have Windows XP home and show some numbers with OEM written.. Then what features are disabled??
Everything is Possible
cooldip10 is offline
Old 14-06-2007, 01:12 PM   #13 (permalink)
"The Gentleman"
vish786's Avatar
Original equipment manufacturer, or OEM, is a term that refers to a situation in which one company purchases a manufactured product from another company and resells the product as its own, usually as a part of a larger product it sells. However, there is confusion among many as to whether OEM refers to the company that buys the product and resells it or the company that originally manufactured the product.
like whenever u get a cd or dvd writer u also get powerdvd software with it. this is OEM version
why dont u guys google
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
FC5 is full of bugs! paragkalra Open Source 4 24-06-2006 07:58 PM
Quick Erase And Full Erase....Whats The Difference???? hell_storm2004 QnA (read only) 1 04-03-2006 06:11 PM
Not getting the full space of HDD Sankalp Hardware Q&A 4 01-02-2006 03:35 PM
Winamp 5.092 Full Sourabh Software Q&A 6 31-05-2005 01:00 AM
xp sp2 full of holes prabhatmohit QnA (read only) 4 22-11-2004 10:08 PM
