Old 06-06-2007, 07:07 PM   #1 (permalink)
 MacManiac
jamesbond007's Avatar
Default Copy Protect my DVD
I was looking for a software or a method to copy protect my home made video DVD. I have to give that DVD to my relatives, they have a PC. I want them to watch the DVD on DVD Player but do not want them to copy the DVD to their PC.
I am quiet sure DVD Shrink, DVD Decrypter or Alcohol are the worlds alien to them, they simply have no idea what they are!! So I am not looking for any strong DVD Enncryption, anything that can just prevent copying of the DVD to PC will be enough.
Why doesn't Airport automatically connect to the default Wireless network after a power cut ??
jamesbond007 is offline
Old 08-06-2007, 07:31 PM   #2 (permalink)
CA50's Avatar
Default Re: Copy Protect my DVD
HI pal i have no idea but i too need the same .
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 08-06-2007, 08:11 PM   #3 (permalink)
"Technologic"
Apollo's Avatar
I don't know about a particular software that copy-protects homemade DVDs. But if you ask to me, what's the point? There isn't a single copy-protection procedure that works 100% or hasn't been cracked.
One great use of words is to hide our thoughts.
Apollo is offline
Old 08-06-2007, 10:20 PM   #4 (permalink)
a_g = JPKN
s18000rpm's Avatar
maybe this might be helpful Make Copy Protected CD
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 08-06-2007, 10:37 PM   #5 (permalink)
@apollo , how many ppl try to dump discs using alcohol or something else ?
most try nero as it is bundled with most recorders . so if a copy protection can prevent disc copy from nero , most ppl cant copy it . this is my idea , u may not agree . but something is better than nothing . so any idea of a copy protection that overcomes nero ?
sagargv is offline
Old 08-06-2007, 11:19 PM   #6 (permalink)
Anindya's Avatar
Thumbs down Re: Copy Protect my DVD
Hey for the past few months even i am looking for this kind of software. I have even posted twice in this forum asking but to no avail. My purpose is the same as urs(Jamesbond007).
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 08-06-2007, 11:35 PM   #7 (permalink)
The Sexy Beast
nero is used to copy the disc entirely i want none of the contents to be copied or made image of
ratedrsuperstar is offline
Old 09-06-2007, 12:47 AM   #8 (permalink)
dOm1naTOr's Avatar
There is an option to password protect discs while burning on Ashampoo Burning s/w. try that
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 09-06-2007, 01:14 AM   #9 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
^^ i use ashampoo , cudnt find that option, can u help...
n00b forever...
~Phenom~ is offline
Old 09-06-2007, 10:15 AM   #10 (permalink)
in nero , if u can stop copy process after it has copied data ( at 99% ) or stop copying at 1% by some method like bad sector or something , it shud be enough.
sagargv is offline
Old 09-06-2007, 12:48 PM   #11 (permalink)
Anindya's Avatar
Question Re: Copy Protect my DVD
What about vcds or video dvds?
www.techani.com
Anindya is offline
Old 09-06-2007, 01:00 PM   #12 (permalink)
"Technologic"
Apollo's Avatar
http://www.cd-writer.com/cd_dvd_copy_protection.html
Apollo is offline
Old 11-06-2007, 01:23 PM   #13 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
hey bt by mistake or else UR DVD gets scraches ......... ur imp data is LOCKED 7 wont b able 2 backup or copy it .......
best option keep in safe place where nobody knows it ...........
& dont lend it 2 ur ppl ....... just say "its with my frd" .......... i always do that, thus protect MY PRECIOUS DVD`S ............
ax3 is offline
How to copy-protect a CD ro DVD? Anindya QnA (read only) 1 26-11-2006 01:13 PM
Copy Protect Video CD aku Software Q&A 1 07-11-2005 12:37 AM
Copy Protect CD from Copying !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! sagargv QnA (read only) 1 18-10-2005 12:51 PM
Copy protect cd champ_rock QnA (read only) 3 17-09-2005 12:18 AM
