Old 20-02-2005, 08:19 PM   #1 (permalink)
Default your reply-please.
1. For Lens Cleaner, somebody recommends for Manual Cleaning and somebody recommends for Software for the purpose. What is your opinion, Sir?
2. When I do by clicking Start-Find-Files or Folders, it appears a Dialogue Box (Find: All Files). In this place the options Column (as Named) there, the Files or Folders we searched for once are stored permanently. How to avoid such option, Sir?
3. Is there any possibility of storage of any Files (in Word or Excel or Internet Files or websites saved by us) on any place in my Computer automatically that to even without my knowledge?
4. I heard that any Files or others can be stored secretly in a place where the neighbors cannot find such Files. How it is possible, Sir? Your detailed reply may be helpful to me, Sir?
kumarn_2004 is offline
Old 20-02-2005, 08:28 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
humm office documents has an auto save option it saves ur data (by defoult) every 10mins..... & internet files comes to ur temp folder.... cant say the extact address as dont know what OS u r in......
for other question wait for others.... i cant answer them.....
Choto Cheeta is offline
Old 20-02-2005, 08:34 PM   #3 (permalink)
Rebooting
i cant make out this question..... but i gues u need to develop a spy ware to do so..... )
Old 20-02-2005, 08:40 PM   #4 (permalink)
Rebooting
i gues u r talking about clinnig ur CD/DVD drive..... if it is, then both the option r wrong.... u need a hardware..... ..... its called CD lens cleaner.... run it.... it will clin ur drive....
Old 20-02-2005, 09:37 PM   #5 (permalink)
Ethan_Hunt's Avatar
Default Re: your reply-please.
Hmmm....now theres no software lens cleaner as such....cause its a hardware component and the lens is the intergral part of CD-Rom,hence a lens cleaner is recommended as it attempts to clean the accumulated dust particles and stuff from top of it
I guess u'll need need to download a tweak utility which will clear the Find folders history....try downloading Total privacy cleaner for this purpose http://www.tomdownload.com/internet/...al_privacy.htm or privacy Eraser http://www.privacyeraser.com/download.htm
this can happen in the event that someone else has an access to ur pc besides u....or that u are connected 24Hrs to the net....also visting certain cracks and porn realted websites lead to entering of trojan and other viruses which can cause possible damage to ur pc Also a risk of spywares now-a-days which create a great hinderance
Well i guess there are file hiding softwares available on the net which can be used to hide desired files or folders....u can also do this by right clicking on a file or a folder and go to properties and then select the hidden option in it and press ok...and ur file is hidden
And lastly Kumarn.....are u a professor or sometin mate....cause u sound too formal in all ur posts No probs just loosen up a bit 8)
Ethan_Hunt is offline
Old 21-02-2005, 02:01 AM   #6 (permalink)
@saurav: y couldnt u answer all the questions in the same post??? did u have 2 post thrice??? look at allwyn's post....
Nemesis is offline
Old 21-02-2005, 02:08 AM   #7 (permalink)
Laptoping
Sourabh's Avatar
MATRIX RELOADED
Oracle:wht does every man want, more POSTCOUNT
Sourabh is offline
Old 21-02-2005, 02:38 PM   #8 (permalink)
enoonmai's Avatar
In addition to the software allwyn mentioned, you can always download the TweakUI Powertoys from Microsoft for your OS and under Paranoia (PowerToys for Windows XP seems to have left this feature out under Explorer, you can only clear the Recent and Run histories) you can opt to "Clear Find History at logon". Alternatively, you can start regedit and navigate to :
HKEY_CURRENT_USER\Software\Microsoft\Search Assistant\ACMru\ and under one of its folders, you will be able to clear the Find Files history.
This works for Windows XP, for other OSes you can do the same by navigating to the HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\Doc Find Spec MRU and delete the files.
Note that these give you the option of selectively deleting the files you don't want instead of clearing everything out.
If its an Internet file you're saving, you can bet it will be stored in the broiwser cache, or more commonly the Temporary Internet Files folder under Windows (for Windows 9x/ME) and under C:\Documents and Settings\<username>\Local Settings\Temporary Internet Files
As for Office documents, they are never stored anywhere else in the place other than which you specify. However, if you download an Office document from the Web, you will find a copy of it in Temporary Internet Files. Also, if Office happens to crash with a document open, expect to find a .tmp file related to the document you were working on in the same location as the saved document.
Well i guess there are file hiding softwares available on the net which can be used to hide desired files or folders....u can also do this by right clicking on a file or a folder and go to properties and then select the hidden option in it and press ok...and ur file is hidden Wink
Remember if you do that, and you have set Windows not to show hidden files and folders, you will not be able to see the folder yourself and you will have to toggle the show/hide option everytime you want to access it. A better option would be to use the third party software like allwyn said. There are tons of them available on the Net, all you have to do is Google for it and pick your software of choice.
Originally Posted by Sourabh
MATRIX RELOADED. Oracle:wht does every man want, more POSTCOUNT
Dont do around misquoting the Matrix around to your own advantage, man. Postcount? When was the last time you got a CT scan?
Playing FEAR XP/LSW2
enoonmai is offline
