Old 05-06-2007, 08:59 AM   #1 (permalink)
Neil is Here...
coolendra's Avatar
Question why is it blocked...!!
Guys... i wz downloading a file using bitcomet...!!..
frst day it wz downloading fine...but since yesterday it started showing a steep dwnfall in the dwnload speeds...!!
Earlier dwnload speed : 144 kbps
current dwnload speed : 7-11 kbps
earlire upload speed : 40-50 kbps
current upload speed 40-50 kbps...
nd this is really annoying me...
the status bar of the client shows BLOCKED : 59.178.47.146
i have heard bout MTNL blocking demonoid..but this isnt a demonoid torrent...
is ISOHunt also blocked by MTNL ???
I am using 590NU
I hav NAV2007 installed...nd windows firewall enabled...but bitcomet is in the exception list..
Please guys....can sum1 help me out.???
If ELECTRICITY comes from ELECTRONS .. then i am sure MORALITY comes from MORONS
coolendra is offline
Old 05-06-2007, 09:58 AM   #2 (permalink)
sachin_kothari's Avatar
Default Re: why is it blocked...!!
it seems that ur port is having some problem.
try changing the listening port.
sachin_kothari is offline
Old 05-06-2007, 10:23 AM   #3 (permalink)
Neil is Here...
coolendra's Avatar
^^ nd how do i change my listening port ???...
ne other alternative solution ???
Old 05-06-2007, 01:55 PM   #4 (permalink)
what torrent client r u using?
Old 05-06-2007, 03:57 PM   #5 (permalink)
Neil is Here...
coolendra's Avatar
i am using bitcomet presently
Old 05-06-2007, 11:28 PM   #6 (permalink)
UbuntuUser
cynosure's Avatar
I dont know about bitcomet but there should be an option of "port encryption" in the connection options (or any other options: advanced for instance).
Enable this option. This basically stops your ISP from poking its nose to block your connection and reduce your download speed.
Try this and reply.
cynosure is offline
salary .. blocked.. medigit Chit-Chat 11 26-12-2008 04:38 PM
p2p blocked!!! phanibhushan Software Q&A 5 04-04-2007 01:55 AM
ISU Blocked URL?? HELP... Manshahia QnA (read only) 5 01-02-2007 12:23 PM
am i being blocked?(in msn live) jz2linkinpark QnA (read only) 4 26-10-2006 05:58 PM
Blocked or not abdulraqeeb33 QnA (read only) 8 14-12-2004 02:39 PM
