Yo guys,
Can anyone suggest a good vcd cutting tool other than VCD Cutter or Super Decoder. All the better if it's something free.Also it must be able to cut directly from VCD's without having to store the DAT onto the hard disk.And It should also support ALL DAT files,Unlike some proggies like VCD Cutter which can't open certain VCD's.Super Decoder is a neat piece of work,but the problem is that it doesn't save the clips in the DAT format,
instead it uses a proprietary form of MPG which is not supported by VCD players. Any bright Suggestions ?!!!
Cheers,
