Re: svhost.exe problem
If it is svchost.exe then its a core windows file that helps dll files with some stuff. If its any other filename then its a virus. If its svchost itself then you cna go by diabling the Automatic Update service and delete the Service Distribution folder in C:\Windows folder. Then your machine will work properly.
