Old 20-02-2005, 03:26 PM   #1 (permalink)
Default Compression help
Need help to reduce dat file .
i need to copy these 882mb dat file size to another 700mb cd !
i tried to over burn with nero and the result was burning failure and the cd contents did not work too.
any method to compress dat further so that i can fit it to 700 mb VCD
vijaythefool is offline
Old 20-02-2005, 03:45 PM   #2 (permalink)
vysakh's Avatar
if it is a VCD u can directly copy it into a 700MB CD because VCD is based on the 80min track
if that too doesnt work convert it into divx using virtualdub or dr divx
Incompatible message format
vysakh is offline
Old 20-02-2005, 03:48 PM   #3 (permalink)
its not possible
because the divx will be encoded back to the previous size while burning to vcd
Old 20-02-2005, 03:59 PM   #4 (permalink)
The size is not a problem but a cd can oly store upto 80 mins.
Whats the total lenghth of ur vcd.U cant store over 80 mins.
Lovedeep Wadhwa
cheetah is offline
Old 20-02-2005, 04:03 PM   #5 (permalink)
but how can u do that ?
Old 20-02-2005, 04:08 PM   #6 (permalink)
Well mins=mbs for any VCD that meets the standard
Do I really need a signature to be unique?
allindrome is offline
Old 20-02-2005, 04:11 PM   #7 (permalink)
any thing more to discuss reguarding compression ?
Old 20-02-2005, 04:15 PM   #8 (permalink)
Why not suggenst me some software to do this ?
Old 20-02-2005, 04:20 PM   #9 (permalink)
vysakh's Avatar
i told u just copy the VCD
vysakh is offline
Old 20-02-2005, 04:22 PM   #10 (permalink)
hey iam online on yahoo add me vijaythefool@yahoo.com
Old 20-02-2005, 04:26 PM   #11 (permalink)
swatkat's Avatar
if the source dat file is in a CD , then using any burning software u do a CD to CD copy using normal blank CDs.....
make sure not to use the option On Fly Copying.....
if the dat file is in Hard Disk , nothing much can be done, one option is to split it into two parts using any programs like VCDClipper or VCDCutter, and then burn in two CDs....
http://www.canalsw.com/product.php%5...Dcanalsoftware
http://swatrant.blogspot.com/
swatkat is offline
Old 20-02-2005, 04:29 PM   #12 (permalink)
Thx swat kat ! that used to be my normal way of copying but now my digit dvd has gone one repair right on the second day i am trapped !
i sold out my old lg ! did a big mistake !
Old 20-02-2005, 04:32 PM   #13 (permalink)
Any codecs can help me out ? is there any ?
should be atleast one ?
Old 20-02-2005, 04:57 PM   #14 (permalink)
hack expert's Avatar
u can try the .mp4 convertor convert the vcd to .mp4 format this format is too small my 700 movies reduces to merely 300 mb wuality is also good
well u can store atleast 2 movies in 1 cd
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 20-02-2005, 05:00 PM   #15 (permalink)
Mp4 means have to use divx codec ?
Old 20-02-2005, 05:11 PM   #16 (permalink)
use DivX ..yaar! simply the best compression for Videos ... go for it!!!
gud luck
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 20-02-2005, 05:37 PM   #17 (permalink)
vysakh's Avatar
if u use divx the when u burn it as VCD, it goes back to the original size
vysakh is offline
Old 20-02-2005, 07:27 PM   #18 (permalink)
ok! then try out Xvid compression .. great compressor .plus..
It's a freeware! .. & vysakh I'm not so sure abt ur information gonna try it ..
Man! use VCD Clipper! if Xvid doesn't work! ..
Gud luck !!
Old 20-02-2005, 08:31 PM   #19 (permalink)
enoonmai's Avatar
The best thing to do in your case is to get any converter program, copy the .dat file to the hard disk, open it in the converter and select export to AVI, and specify a target file size of 700MB. Once its done, all you have to do is open Nero's VCD creation window, and drag and drop the file. Nero will automatically recode the file back into the VCD MPEG format, and this time, you will be able to fit it onto a CD.
Playing FEAR XP/LSW2
enoonmai is offline
Old 20-02-2005, 08:47 PM   #20 (permalink)
busyanuj's Avatar
don't use Dr. Divx if you intend to make it a VCD.
instead, use VCD Cutter to cut the 882 mb file into two parts of about 450 mb each, then burn those parts onto 2 separate cds as VCDs (disc 1 and disc 2)
busyanuj is offline
Old 20-02-2005, 08:53 PM   #21 (permalink)
u still havent mentioned whether the dat is on hdd or on cd
if u have the cd create a cd image and burn the image
dont just copy the dat file
No Mercy, No Limits.
theraven is offline
Old 20-02-2005, 09:33 PM   #22 (permalink)
The file is on the hard disk its the part one of the movie i dont want to bring up a third disc
Which software he has mentioned ? than can compress dat further if so it can come handy .
none of the compressors work because once nero starts to burn the file ,it will be converted back to dat file with almost the same file size
if some thing can be done its OVERBURNING without causing any harm to the drive !
wonder how the original copy was made
