Old 20-02-2005, 03:18 PM   #1 (permalink)
Default Need for speed u 2 music
hey i got the link friends i got it !
hope no one use the word legal .....
[Edit GNUrag: No links to warez site plz]
vijaythefool is offline
Old 20-02-2005, 03:47 PM   #2 (permalink)
vysakh's Avatar
hmmm... i better rip it than buy it
anyway thanks for the link
Incompatible message format
vysakh is offline
Old 20-02-2005, 03:51 PM   #3 (permalink)
is it possible to rip nfs u 2 tracks ?
Old 20-02-2005, 07:43 PM   #4 (permalink)
enoonmai's Avatar
Ha, easier said that done. EA figured everyone was just ripping their trax, so they went ahead and secured the .mus/.ast files tighter than a ... well, never mind, its tight enough.
All data is stored in the sdata.viv file in the SDATA folder, but the music is "interactive" which means that while NFSU had a song for each physical block, NFSU2 stores the files across multiple physical blocks. Plus, the damn thing is protected with a lot of data that frankly requires hex editors and some bit of knowledge about their working to bypass to even GET at the .mus files. And once you DO extract them after an entire night's work, forget about converting them into a playable format.
The best thing to do is to plug your PS2/Line Out to your Line In and open a music editing program (Audition/SoundForge/CEP) and then hit Record and then play the EA Trax through the Trax selection in the game. That's what I ended up doing.
Playing FEAR XP/LSW2
enoonmai is offline
Old 21-02-2005, 04:09 PM   #5 (permalink)
Back From Deathstar
Darthvader's Avatar
GOod point man
Darthvader is offline
Old 22-02-2005, 10:07 AM   #6 (permalink)
KoRn's Avatar
hey guys can u give me a simpler or more UNDERSTANDABLE way of copying the nfsu1 tracks into a cd
KoRn is offline
Old 22-02-2005, 11:03 PM   #7 (permalink)
Try different utilities at http://www.nfsunlimited.net This is a good website which I came across.
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
Old 23-02-2005, 10:41 AM   #8 (permalink)
A Year Closer To Heaven
ctrl_alt_del's Avatar
I just looked it up on the Net and then downloaded the Tracks.
ctrl_alt_del is offline
Old 23-02-2005, 06:25 PM   #9 (permalink)
vysakh's Avatar
i recorded it from the game itself
thats what i meant in the earlier post
vysakh is offline
Old 23-02-2005, 06:44 PM   #10 (permalink)
Ethan_Hunt's Avatar
Same here dude.....Got it from BT long back....plus who would go for that lame "extarction of Music from game process" when u can just download those tracks
fair enough tracks....
V for Vendetta
Ethan_Hunt is offline
Old 23-02-2005, 06:52 PM   #11 (permalink)
enoonmai's Avatar
I wouldn't say that, most game music is either stored as pure, uncompressed WAV or recorded in the highest bitrate MP3 / OGG, and you have to listen to them to know how good they really are. Plus, if guys like us didnt rip the music, transcode them and put them up for download, where do you think you're gonna download from?
enoonmai is offline
Old 23-02-2005, 08:16 PM   #12 (permalink)
Try using sony sound forge it records at a very good quality !
