Old 03-06-2007, 08:07 PM   #1 (permalink)
Gracias Senor
dreams's Avatar
Unhappy Whr is my QUICKLAUNCH ???
Hi guys..
For sometime ago i hv lost my quicklaunch for every restart..i restart my pc the quicklaunch dissappears..again i bring it bac align the icons..lock it..its safe..one more restart its gone again..
i hv googled and got lots of tricks but still doesnt work..so decided to get the solution frm here..this site i trust a lot thn googlin..
Keep my faith alive..
TIA
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 03-06-2007, 08:37 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Whr is my QUICKLAUNCH ???
Open regedit and goto:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
In right-side pane make sure there is no DWORD value with the name NoSaveSettings, if its there delete it or change its value to 0
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 03-06-2007, 08:41 PM   #3 (permalink)
Gracias Senor
dreams's Avatar
I dont find NoSaveSettings in thr..i tried all these steps b4 when i googled..nothin seems 2 work vishal..
dreams is offline
Old 03-06-2007, 08:45 PM   #4 (permalink)
Q6600 Underclocked
sourishzzz1234's Avatar
Asuming that u r running XP right click on the task bar at the bottom of your screen. Then goto-->Toolbars-->quick launch
Originally Posted by dreams
Hi guys..
TIA
try for some anti-virus/antispyware
Core 2 Quad Q6600 2.4Ghz (OC->2.7Ghz)
Cooler Master Hyper 212 Plus
aBIT IP-35 E
1*2GB DDR2 800MHz Zion RAM
320GB Seagate Baraccuda
Sparkle nVdia GeForce 9400GT 512MB
Last edited by sourishzzz1234; 03-06-2007 at 08:45 PM. Reason: Automerged Doublepost
sourishzzz1234 is offline
Old 03-06-2007, 08:51 PM   #5 (permalink)
Gracias Senor
dreams's Avatar
thnx 4 ur reply..when doin this it cums bac..once i restart it again goes..i hv clearly mentioned my prob in the post buddy.
dreams is offline
Old 03-06-2007, 08:53 PM   #6 (permalink)
Microsoft MVP
@dreams
Pls post all existing DWORD values under the key I mentioned in previous post. Actually there r lots of DWORD values, which can be set for such restrictions.
Old 03-06-2007, 09:10 PM   #7 (permalink)
Gracias Senor
dreams's Avatar
here it is vishal..
dreams is offline
Old 03-06-2007, 09:29 PM   #8 (permalink)
Microsoft MVP
^^ I didnt find any DWORD value which can cause this problem. Pls also post a screenshot of following key:
HKEY_USERS\.Default\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
Old 03-06-2007, 09:47 PM   #9 (permalink)
Gracias Senor
dreams's Avatar
I found only 2 keys..
Default - No value set
NoDriveTypeAutoRun - 0x00000091 (145)
dreams is offline
Old 03-06-2007, 10:45 PM   #10 (permalink)
Microsoft MVP
Really strange! Seems some virus/spyware problem.
Pls download "HijackThis" from http://www.hijackthis.de/ and scan ur PC with it then post log file contents here.
Old 03-06-2007, 10:52 PM   #11 (permalink)
left this forum longback
praka123's Avatar
Talking Re: Whr is my QUICKLAUNCH ???
....may be a Linux user can help;sometimes this soltn may work eppadi nanba
Quick Launch Toolbar Disappears
The problem:-after every reboot or shutdown the quick launch toolbar disappears.
Solution:-
It may be due to a malware- BlazeFind .Check whether there is any Search Assistant toolbar in the Taskbar or not.
If it is present then:-
Start>Run>Regedit>ok
now navigate to:-
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\Cu rrentVersion\Winlogon
In the right-pane, change the value of Userinit to "C:\WINDOWS\system32\userinit.exe,"
Type the above value exactly.Do not forget to add the comma at the end.
(without the quotes). Exit Registry Editor and restart Windows.
Very helpful references:-
Cannot Create Toolbar - Quick Launch (Line 296)
http://www.kellys-korner-xp.com/xp_tweaks.htm
Taskbar Repair Tool Plus! Quick Launch - Repair
http://www.kellys-korner-xp.com/taskbarplus!.htm
Restore Winlogon\Userinit (Line 263 right)
source:
http://xperiencexp.blogspot.com/2005_02_01_archive.html
praka123 is offline
Old 05-06-2007, 10:35 AM   #12 (permalink)
Gracias Senor
dreams's Avatar
Hi guys..
For some reason its workin now..dnt knw which is the exact solution..cos i hv tried loads of tricks..also one thing i really did was copied the quicklaunch folder in all the user accnts, like all users, myself, current user..
may be this might of resolved the prob..but not sure
Anyway thnx 4 all the ppl who spent their precious time in resolvin my issue..
thnx once again.
dreams is offline
Quicklaunch and also MyComputer problem EagerBeaver QnA (read only) 4 30-12-2006 11:38 PM
Scripting QuickLaunch rohan Tutorials 2 20-05-2005 12:05 AM
