Old 03-06-2007, 07:29 PM   #1 (permalink)
clmlbx's Avatar
Default System Get's Restart
system get's restart and after restart box appears and say's system has recovered from a serious system error and log files have been created .
I am using windows xp sp2 + autopatcher may 07
hardware :-
E4300
INTEL ORG. D946GZIS
1 GB RAM
I AM INCLUDING LOG FILES
DOWNLOAD
clmlbx is online now
Old 03-06-2007, 07:34 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: System Get's Restart
Have you made any recent change in hardware or software??????
ravi_9793 is offline
Old 03-06-2007, 07:41 PM   #3 (permalink)
clmlbx's Avatar
Purchased All Three Of Them
Yesterday Installed Xp & All Softwares
Old 03-06-2007, 11:15 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
ur motherboard support C2D (E4300) processor...and it support DDR2 667 MHz and DDR2 533 MHz .Make sure you have installed compatible RAM with ur motherboard.
There can be few more causes of system restart:
1)Overheating
These days heat wave is high in air.Your cabinet sud have a extra fan. for proper colling.To check this cause..please open the cabinet and than run the system.
Please download speed fan .. it will tell you the temperature at which your CPU and hard drives are running.Download it from here:
http://www.almico.com/speedfan.php
2)Another cause can be bad memory.There is chance that the memory(RAM) you have installed is bad.
To check this...try with another RAM stick.
3)There is a property in win Xp..that restats the sysstem automatically when system is having any error.You can turn it off.To do this ,follow these steps:
start-->>right click my computer-->>properties-->>click on advance tab.You can see something like this:
click on Settings in the Startup and Recovery section.A page willopen like this
Just uncheck the box "Automatically Restart" in the System failure section..like this:
Old 03-06-2007, 11:45 PM   #5 (permalink)
clmlbx's Avatar
I have done everything u spotted .
but unsolved
Old 03-06-2007, 11:50 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
^^^^^^^I have just edited my post..plz read it again.Than plz post the result.
Old 04-06-2007, 09:37 PM   #7 (permalink)
clmlbx's Avatar
nOTHING HAS BEEN SOLVED .
I ALREADY TRIED ALL THIS BEFORE POSTING HERE
BUT ............
UNSOLVED
Old 04-06-2007, 09:42 PM   #8 (permalink)
TechTin.com
ravi_9793's Avatar
If none of mine solutuion work..than I think you sud show ur system to the vender from where U have bought.May be MB problem.
Old 04-06-2007, 09:54 PM   #9 (permalink)
clmlbx's Avatar
I Changed My Motherboard .
Before Changing Mb There Was Bsod Problem But Now It Is Ok .
But Now It Is Restart Problem
Old 04-06-2007, 09:57 PM   #10 (permalink)
TechTin.com
ravi_9793's Avatar
ohhh hoo.....
I think U must be a very sad guy..new system with so many problems.See..giving suggestion from here is always easy. I will suggest you to take ur system back to ur vender. May be some other probem..he will fix tham are replace some parts.
Old 04-07-2007, 05:09 PM   #11 (permalink)
I'll xploit ur Territory
niraj trehan's Avatar
bsod HELP
hey help needed
read the dreadful story........
stage1
i got 7300gt , got vista ultimate and then pop up the dreadful blue screen started coming at the place where v have to enter our name......later stages i thot that can b due to ram conflicts.... i got that changed ..... bt nothing happened ....after some time i uninstalled vista and vas back to xp .... bt the story wasnt over...later stage of xp i starrted getting blue and red lines all over my screen.........
2nd stage
i got my grphcs card faulty vich was faulty,,,,,,,,,,,and gt 8800gtx xxx 768mb and then came prblem of finding the power supply vendor ..after moaning at forum i gt the place and gt the psu of coooler master and went home to c my rig working wid vista 1st time
in the place where we enter our password to enter the os
there is flickering and nt the blue screen
bt as soon as i click to upgarde my basic score which is 1(yet another problem)
i get blue screen or if i play any game eg spiderman3 i get that blue screen....physical dump memory....
i tried changing ram bt doesnt help....howver windows xp is fine.......
......bt again the blue screen......
can any 1 tell me whats this !!!!!!
thx for patient reading
my config
motherboard:intel 945 gnt
ram:2 gb
graphic crd:8800 gtx xxx 768mb
processor entium d 2.8
power supply:600w cooler master
can u plz give me link to the place frm where i can download the latest driver for my graphic card.....thx
<<XFX 680i TLi chipset>>Dual core 2.8Ghz>>2*1GbTranscend 800 hz>>8800 GTX XXX 768 Mb..GTX 260 862 Mb now GTX 280 1 Gb>>Cabbi CM 690 Nvidia SLI>>CM OEM 600w>>APC 1Kva UPS>>
niraj trehan is offline
Old 05-07-2007, 02:20 AM   #12 (permalink)
Is actually a real word..
niraj trehan try going to Nvidia's website and search for vista drivers for your card. how new is your sys and is it a homebuilt or did you buy it as one unit from a vendor?
Liggy is offline
Old 05-07-2007, 02:24 PM   #13 (permalink)
its 3 weeks old....
got it assembled.....
Old 06-07-2007, 01:09 AM   #14 (permalink)
so what does the BSOD say?
niraj trehan I am assuming by looking at other thread (exact same post) that your issue is solved?
Liggy is offline
Old 06-07-2007, 02:04 PM   #15 (permalink)
Unhappy Re: System Get's Restart
liggy i must say u r after me
man that bsod prob is solved bt there is a problem appearing in vista and xp and in any other thing that uses graphics...and the prob is that white lines r appearing all over the screen ,..... iwanted to post the pic bt cant shrink it to that small....
Old 08-07-2007, 09:28 AM   #16 (permalink)
using CRT monitor? might be going (my cousin's did that and he'd give it a good 'Whack' to smarten it up!, which worked kinda till the monitor gave up). maybe the grpfx card is faulty
Liggy is offline
PC does not restart spp_itim Hardware Q&A 5 17-01-2007 10:21 AM
system restart!! gofeddy Software Q&A 8 14-12-2006 09:33 PM
System Restart Automatically !!! sauravktr QnA (read only) 6 12-11-2006 06:16 PM
restart in ms dos from win xp Ishan Software Q&A 8 01-06-2006 09:32 AM
+3.3 Voltage problem. System restart prashantisonline Hardware Q&A 1 26-11-2005 01:03 AM
