Old 02-06-2007, 03:58 AM   #1 (permalink)
bajaj151's Avatar
Default Tricky One !!!
In Vista,how to add Insert option in drop down menu when we right click on optical drives....to insert the tray automatically using Insert option..
bajaj151 is online now
Old 03-06-2007, 11:21 AM   #2 (permalink)
God of Mistakes...
Garbage's Avatar
Default Re: Tricky One !!!
U have to play with Registry.
I think Mr. Vishal Gupta has given a nice tutorial on that.
I don't know how to attach files here. OW I can give u that registry key & DLL file I used for XP. SORRY
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 03-06-2007, 11:54 AM   #3 (permalink)
bajaj151's Avatar
Ya..I know abt Vishal tutorial....tht was fantastic...but...tht worked only for xp....I am here ...for d solution for vista.....thx..
Old 21-07-2007, 06:12 PM   #4 (permalink)
bajaj151's Avatar
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
Old 21-07-2007, 06:14 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
yep. That was following tutorial:
TUTORIAL: Add "INSERT" Option in CD Drive Context Menu !
And it works perfectly in Vista at least for me but a few members mentioned that it didnt work for them in Vista.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 21-07-2007, 06:21 PM   #6 (permalink)
bajaj151's Avatar
thxx...
lemmee tryyy again...
i tried again...but its not working.........any solution ??
Old 21-07-2007, 06:26 PM   #7 (permalink)
Microsoft MVP
Try this one also:
200KB CD Tray Insert/close App
Old 21-07-2007, 06:35 PM   #8 (permalink)
bajaj151's Avatar
ya..its working....but...what's the problem with the solution u posted....why its not working on my pc...??
Old 21-07-2007, 06:51 PM   #9 (permalink)
Microsoft MVP
May be the DLL I used is not compatible for Vista?
Tricky Folder mohanty1942 QnA (read only) 6 07-10-2006 02:21 PM
tricky ques ravix Open Source 5 02-07-2006 01:42 PM
Tricky problem: HDD issue? SpitefulPentium QnA (read only) 8 12-01-2005 09:34 AM
