Old 31-05-2007, 10:20 PM   #1 (permalink)
Resident Fanatic
Manshahia's Avatar
Default Duped By the vendor??
Hi guys,
i purchased a 512 MB DDR-2 Ram...
And the vendor told me that its 533 MHz.. for 1K... some company i think Dyanet...
Now when i ran a software it showed this..
He duped me??
Manshahia is offline
Old 31-05-2007, 11:12 PM   #2 (permalink)
clmlbx's Avatar
Default Re: Duped By the vendor??
check out the sticker that is on the ram stick .
full info is on that lable that is on ram stick .
which type of ram ( ddr1 , ddr2 )
how man mhz ( 533 ,667 )
how much ( 1 gb ,512 )
all of them
so check it out ?
clmlbx is online now
Old 31-05-2007, 11:34 PM   #3 (permalink)
ashfame's Avatar
try checkin wid other App or thro' BIOS
Edit:
No its correct!
chk da table here: http://en.wikipedia.org/wiki/DDR2_SD...tion_standards
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 01-06-2007, 12:34 AM   #4 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Also check what your motherboard supports? Sometimes due to motherboard limitations also RAM behaves at lower frequencies.
navjotjsingh is offline
Old 01-06-2007, 04:40 AM   #5 (permalink)
Resident Fanatic
Manshahia's Avatar
i think here is the answer but can anyone tell me openly...
i cudnt get the point here..
Old 01-06-2007, 05:01 AM   #6 (permalink)
Beneath The Eyelids
The Outsider's Avatar
it running fine
from wikipedia
The key difference between DDR and DDR2 is that in DDR2 the bus is clocked at twice the speed of the memory cells, so four words of data can be transferred per memory cell cycle.
so the speed of the memory cells is 266MHz but its clocked at 533, thats what makes it DDR2
The Outsider is offline
Old 01-06-2007, 05:48 AM   #7 (permalink)
baccilus's Avatar
Slower DDR1 RAM is much more costlier than DDR2 RAM. So this can't be true. This is best seen from BIOS.
Appreciate me now and avoid the rush!!
i5 2500K || 8GB DDRIII 1600 MHz RAM || Zotac GTX560Ti || Samsung 2233sw || Corsair GS600
baccilus is offline
Does my vendor cheat me???? madmax_tt Hardware Q&A 16 16-04-2007 11:06 PM
suggest me a trusted ps 2 vendor mandar5 Gamerz 25 17-02-2007 10:59 AM
digit has duped us. manishksingh97 Fight Club 3 23-10-2006 06:22 PM
help me - machine hanging like hell - vendor help less amit_arya QnA (read only) 8 01-06-2005 11:14 AM
