Old 19-02-2005, 06:26 PM   #1 (permalink)
Just Do It
Charley's Avatar
Default Broad band speed problem??
I've taken the Dataone connect from BSNL. The speed is supposed to be 256kpbs, but even though i have an old system P-133mhz the speed is only abt 159-170kpbs. My friends also who have latest configs get the same speed ... Is it beacuse of the provider or what .. Cant understand why so less
Charley is offline
Old 19-02-2005, 10:18 PM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Man, i have no such problems (i can connect at 252 kbps), but others in chennai say the same thing....
They say by 10 days to make it proper. Keep ur fingers crossed....
drgrudge is offline
Old 19-02-2005, 11:37 PM   #3 (permalink)
@chacko : have u tried actually overclocking ur 133 . change the jumpers to 150 and then 166 and check which is more stable . this isnt to boost ur net performance , but over all performance on ur pc . btw which os and browser u using ? try opera any version 5 or older for ur config .
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 20-02-2005, 09:12 AM   #4 (permalink)
hack expert's Avatar
as suggested opera is very good also for downloads try leechget or flashget
btw are u talking about the connection speed
n wat speed do u get while downloading some thing
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 20-02-2005, 02:00 PM   #5 (permalink)
Just Do It
Charley's Avatar
Dude, how do i chage that to the 166 using jumpers? What shud i do?
And regdg speed for 256kpbs plan from BSNL, dont u laugh ... I used to get a whopping 20-25kpbs for some time and now 8kpbs, hows that !!
Many of my friends have the same problem too. I have IE5 in the system .....
Charley is offline
Old 20-02-2005, 02:03 PM   #6 (permalink)
drgrudge's Avatar
I have no such problem, i get around 29-33kbps!!!
As i have told u, it takes time to restore normality, wait for some time and see the speed.
drgrudge is offline
Old 20-02-2005, 02:05 PM   #7 (permalink)
Just Do It
Charley's Avatar
Ur a lucky one dude of the lot........LOL
I have downlaod problems too. When I download any file or softie from the net, it completes the download , but the file when opened says this program has performed an illegal operation and will be closed... Some errors r mentioned too .. Then a msg it is due to restrictions on your computer.. Please contact system adminstratr..
I'd had this same problem when i used the ENternet 300 for logging then I reduced the firewall level to medium then it worked fine. That software got corrupt and i'm using the modem[Huawei] config for connection and same problem.. Can u help me dude....
Charley is offline
Old 20-02-2005, 02:06 PM   #8 (permalink)
Rebooting
Choto Cheeta's Avatar
@achacko
u better ask BSNL customer about it.... my frnds use it.... they got it on their home Ph line.... they say if u find (pick up the riciver) chrechi noise over the phone then their is some line pro....
as i said u better ask BSNL....
Choto Cheeta is offline
Old 20-02-2005, 02:09 PM   #9 (permalink)
The " chrechi noise over the phone" is when you connect a phone BEFORE the data/phone spliter given along with the modem. This also causes problems in data downloads check that the phone line comes first to the splitter and then goes to all the telephones also note there are no parallel phones connected to the tele line before the splitter.
**** happens
pradeep_chauhan is offline
Old 20-02-2005, 02:16 PM   #10 (permalink)
Just Do It
Charley's Avatar
They've tried everyhing abt 5-10 times.. right now they've given a direct connection to the pole in the bldg to check it .... The same though....
Guys pls check the quote i mentioned to dr.grudge just 2 msgs above and give me a suggestion on what cud be the problem or a soln..
I've Wind 98 sec edtion in my systm, P-133 mhz, 64mb ram...
Charley is offline
Old 20-02-2005, 04:41 PM   #11 (permalink)
drgrudge's Avatar
Man, Check this out..., how to make a p2p software work with ur firewalls on:
http://www.thinkdigit.com/forum/viewtopic.php?t=12967
I dont use any firewalls with my systeam for this very reason.
@pradeep, hows ur connection?
drgrudge is offline
Old 20-02-2005, 08:07 PM   #12 (permalink)
Just Do It
Charley's Avatar
Mine works even though i dont have that softie installed for Kazaa lite. I get connected instantaneously.....
I really dont understan the catch ........
Charley is offline
Old 20-02-2005, 08:21 PM   #13 (permalink)
Rebooting
another thing.... @achacko@dataone.in how do u cheak ur connection speed?? lots of post about this matter.... the speed depends on lots of things......
Old 20-02-2005, 09:11 PM   #14 (permalink)
Just Do It
Charley's Avatar
Go to the zdnet where there is an option of test my ISP or www.us-mcafee.com/root/speedometer
Charley is offline
Old 20-02-2005, 09:22 PM   #15 (permalink)
Rebooting
tell me do u get same result every time u test ur connection?? i never got same result 2times.....
Old 20-02-2005, 10:10 PM   #16 (permalink)
Just Do It
Charley's Avatar
never... I got a max of 30kpbs & then reduces...... The least i get is 7kpbs...... God forbid it lessens or i'll go & wack that telcom engr black butt....
Charley is offline
Old 20-02-2005, 11:05 PM   #17 (permalink)
Rebooting
some did.... i got this news in our local news paper... BSNL engg got bitten up by few broad band customer in kolkata.....
Old 21-02-2005, 12:17 AM   #18 (permalink)
bitten? Dont tell me that. Calcutta people have come to biting each other. ..... Dog eat Dog Type...... Good to hear that.
**** happens
Old 21-02-2005, 12:19 AM   #19 (permalink)
**** happens
Old 21-02-2005, 12:20 AM   #20 (permalink)
**** happens
Old 21-02-2005, 01:53 PM   #21 (permalink)
enoonmai's Avatar
Man, it depends also on the server you're downloading from, its geographical locations and its current load. Try a connection speed benchmark from a couple of sites to get an average. 7kbps on an ADSL connection.
Playing FEAR XP/LSW2
enoonmai is offline
Old 24-02-2005, 07:29 PM   #22 (permalink)
Default confusion
sify people r offering 256kbps ,700mb limit for 2 months
now my ques is that does the size of temporory internet files which r saved while browsing and saving images frm web pages by right click\saveas will be included in 700 mb ??
paul_007 is offline
Old 02-03-2005, 05:08 PM   #23 (permalink)
Just Do It
Charley's Avatar
BSNL dudes wht is ur speed now , I'm only on the 160kpbs - 20.12 KB range now.... Is it the same 4 u'all
Lemme know
Charley is offline
