Old 31-05-2007, 04:19 PM   #1 (permalink)
LIFE Overclocked!!
pritzdj's Avatar
Exclamation (Plz Help Me) CD erasing option not available...........
Hi.....
I m a Win XP user........ from my "CD-RW drive" erase option is not available but "Write" option is available........ so i'cant erase my CD-RWs..... From Nero also i'cant erase.......
By Linux i can erase my CD-RWs........ but m not a frequent user of Linux..... for only CD erasing option i'cant switch to Linux!!!!!!!!!!!
So please help me out...........
pritzdj is offline
Old 31-05-2007, 04:31 PM   #2 (permalink)
ashfame's Avatar
Default Re: (Plz Help Me) CD erasing option not available...........
Wht msg Nero gives you when you attempt to erase CDRW?
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 31-05-2007, 04:53 PM   #3 (permalink)
Also can you see that CD-RW is correctly detected by either winodws or Nero. XP will show the icon for it which states CD-RW. With Nero when you create a new project then you can see the type of disk that Nero has detected. Are both CD-RW? If not then there are chances that your CD writer is not working properly.
As already asked by ashfame what is the message shown by Nero? If it does recognise the correct media type then it should display/enable the option to erase the media ie. CD-RW.
sandeepk is offline
Old 31-05-2007, 08:37 PM   #4 (permalink)
LIFE Overclocked!!
pritzdj's Avatar
When i try to erase using Nero..... the erase button was disabled...
pritzdj is offline
Old 31-05-2007, 08:49 PM   #5 (permalink)
LIFE Overclocked!!
pritzdj's Avatar
Yes Nero and Windows both detect the CD but in CD-R format..... not in the CD-RW format......... I don't think that my CD writer is damaged because Linux can erase that CD-RW using that CD Writer only.........
Another thing...... I have DVD-Writer installed in my PC..... Both the drives showing the problem in XP.........
pritzdj is offline
Old 31-05-2007, 11:02 PM   #6 (permalink)
Check your ASPI drivers are properly installed. Download the latest version from Adaptec's site.
Anyone who has never made a mistake has never tried anything new
sandeepk is offline
Old 01-06-2007, 11:07 AM   #7 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
mayb u have set writter as IMAGE WRITTER .......... check it out .........
in this option [image] ........ erase is disabled ............
ax3 is offline
Old 01-06-2007, 05:21 PM   #8 (permalink)
LIFE Overclocked!!
pritzdj's Avatar
Can u help how to check............ "IMAGE WRITER".................
pritzdj is offline
Old 01-06-2007, 05:28 PM   #9 (permalink)
ashfame's Avatar
When you open Nero Burning Rom, its just in front of you, look at the toolbars!
It luks lik a address bar!
Confirm there n change if its necessary!
ashfame is offline
Old 02-06-2007, 04:33 PM   #10 (permalink)
ax3
ax3's Avatar
its in FRONT of U .............
ax3 is offline
What is the best option??? debsuvra Mobiles and Tablets 10 21-05-2007 05:05 PM
Mycomputer - tools - folder option??? no folder option jayanbhm QnA (read only) 19 21-05-2007 02:43 PM
How to Remove Hide Option Frm Folder Option Chindi_Chor QnA (read only) 17 23-03-2006 11:18 PM
help !!! CD RW not erasing !!!! abhasbajpai QnA (read only) 15 17-03-2006 11:02 AM
Option thierryhenry_me QnA (read only) 6 09-02-2005 01:58 PM
