Old 30-05-2007, 08:12 PM   #1 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Red face Limewire Pro Probs..
hey buddies..
i download two video songs from Limewire and saved them in this directory ::
C:\Program Files\Limewire\Downloads [ Created my own folder ]
now when i browse to the folder within the limewire directoy..there is no such folder available ...turned on all hidden files and folders but no relief !
now the interesting part...when i open limewire and have a look at my saved files ... the files are present in that folder and i can even launch them. .but that folder isn't opening...
wats the matter wid it ? i don't want to lose my videos...Plz Help
Thnx
BlackBerry7100g.
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 30-05-2007, 09:17 PM   #2 (permalink)
"Technologic"
Apollo's Avatar
Default Re: Limewire Pro Probs..
See if the files are here:
C:\Documents and Settings\Username\Local Settings\Application Data\
Hopefully, there will be a Limewire folder in there(Note: see that you have the show hidden files option checked)
One great use of words is to hide our thoughts.
Apollo is offline
Old 30-05-2007, 11:05 PM   #3 (permalink)
^ no relief ....
Old 30-05-2007, 11:56 PM   #4 (permalink)
D i s t i n c t l y Ahead
saurabh kakkar's Avatar
Smile Re: Limewire Pro Probs..
hey buddy open limewire then go to -> options-> click on saving on left pannen then see the folder location where the files r stored
they r generally stored in Shared folder
saurabh kakkar is offline
Old 31-05-2007, 12:10 AM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
Have people forgotten the most worked on part of an OS?
Start --> Search. Period.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 31-05-2007, 12:10 AM   #6 (permalink)
Genius in making mistakes
bhushan05d251's Avatar
Try to search extensions of those video files in "C" drive e.g. *.avi or *.mpg in search option in explorer.
bhushan05d251 is offline
Old 31-05-2007, 08:02 AM   #7 (permalink)
When i was using the search feature of Windows Vista , no such files found in the entire C: , but when i logged onto Windows XP Prof. n used the feature ...i got my files
can ne1 imagine where my files got stored ::: The Path ::--
C:\Users\Username\AppData\Local\VirtualStore\Progr am Files\LimeWire\Downloads
Thnx Guys For ur Help,
BlackBerry7100g.
Limewire naru QnA (read only) 18 25-06-2006 09:39 PM
limewire pro Nilesh.Ravindran Software Q&A 7 21-06-2006 06:59 AM
limewire ! ! ! ax3 QnA (read only) 4 01-04-2006 06:10 PM
Limewire naru QnA (read only) 10 20-02-2006 08:46 PM
limewire BLITZ~KRIEG! QnA (read only) 16 15-09-2005 10:05 PM
