Old 29-05-2007, 09:34 PM   #1 (permalink)
Gracias Senor
dreams's Avatar
Unhappy Avast VS Kaspersky !!!
Hi all..
After hours of research and searchin multiple pages in this forum finally i settled for Avast Anti-Virus..
For a second thought i need a gud Firewall..Finally after the same steps i settled for Kaspersky..
Here cums the prob..
I tried to install Kaspersky and it shows Avast as a incompatible application..so i need to remove Avast in order to use Kaspersky..
Is it wise to remove Avast and install Kaspersky Anti-Virus and Firewall ??
I be on internet for a loooong time and i need a v.gud Anti-Virus and also do a lot of online shopping so need a v.gud firewall too..
Note - Also i am using Windows Defender.
Help needed techies !!
TIA
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 29-05-2007, 09:51 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: Avast VS Kaspersky !!!
Take a look at this thread by Kiran Tech Mania -> Free Antivirus, Antispyware and Firewall Solutions for Windows®
Don't install multiple antivirus.Install only one
Third Eye is online now
Old 29-05-2007, 09:58 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
remove avast. instal kaspersky internet security. u'l be better off ! keep ur windows defender. use xp-antispy utility to tweak ur xp security settings.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 29-05-2007, 10:13 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
Agree with Sir Anand
Once u install Kaspersky Internet Security u dont need any thing else
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 29-05-2007, 10:27 PM   #5 (permalink)
You gave been GXified
gxsaurav's Avatar
Does KIS comes with a firewall?
about.me/gxsaurav
gxsaurav is offline
Old 29-05-2007, 10:36 PM   #6 (permalink)
Kiran.dks's Avatar
dreams, If you have Kaspersky Antivirus, remove avast!. Retain Windows Defender.
Saurav,
Yes. KIS comes with Firewall too.
Kiran Kumar R
Kiran.dks is offline
Old 30-05-2007, 12:07 AM   #7 (permalink)
for a good antivirus i recommend PC Tools
kushals is offline
Old 30-05-2007, 12:13 AM   #8 (permalink)
Rubik's Uncle!!
Charan's Avatar
Another vote for kaspersky , I never had any problem with kaspersky.
Charan is offline
Old 30-05-2007, 12:33 AM   #9 (permalink)
Alive Again...
satyamy's Avatar
use Kaspersky Internet Security & no need to install any other anti or firewall
satyamy is offline
Old 30-05-2007, 01:20 AM   #10 (permalink)
Security Exp
47shailesh's Avatar
Yes it does
We Love Once, And When We do We do it Well
47shailesh is offline
Old 30-05-2007, 01:25 AM   #11 (permalink)
gxsaurav's Avatar
Cool, then I m downloading KIS for Vista.
So KIS = KAV + Firewall + ????
about.me/gxsaurav
gxsaurav is offline
Old 30-05-2007, 01:39 AM   #12 (permalink)
Rebooting
KIS = KAV + K-Filewall + K-AntiSpyware + K-SpamProtection + K-popup blocker + K-Adblocker + Email Protection + and so on, read more here http://www.kaspersky.com/kis6?chapter=185166750#a
rebooting
ChotoCheeta.com
Old 30-05-2007, 09:08 AM   #13 (permalink)
Gracias Senor
dreams's Avatar
Hi guys..
Thnx for the huge and helpful response frm all u techies..
Accor to the response, i hv a smal doubt..
I hv seen Kaspersky Anti-Virus and Firewall 2 separate s/w avail in market..shuld i install both or either 1 is enough..
If either 1 is enough then which 1 shuld i go for..Anti-Virus or Firewall ??
dreams is offline
Old 30-05-2007, 09:16 AM   #14 (permalink)
Kiran.dks's Avatar
Kaspersky is doing well in Antivirus segment. So I suggest to get Kaspersky Antivirus program and regarding firewall, you can get Zone Alarm Pro Firewall. It's a great firewall program.
btw, if the use is for personal, then I suggest not to invest penny for security protection.
For personal use, the following free package is a lethal pack:
Antivirus: Active Virus Shield (Uses Kaspersky engine and hourly updates)
Antispyware: Windows Defender and AVG Antispyware free version
Firewall: Comodo Firewall or Jetico firewall
You can find all these in the following thread:
Enjoy!
Kiran Kumar R
Old 30-05-2007, 09:43 AM   #15 (permalink)
Sup' dude, Sup'
Originally Posted by dreams
Hi guys..
Forget about Kaspersky Anti-virus and firewall 2 software. Go and get "Kaspersky Internet Security Suite".
ambandla is offline
Old 30-05-2007, 10:14 AM   #16 (permalink)
gxsaurav's Avatar
Hmm....KIS provides lots of thing.
KTM
Comodo & Jetico are not Vista compatible yet.
about.me/gxsaurav
gxsaurav is offline
Old 30-05-2007, 10:22 AM   #17 (permalink)
Kiran.dks's Avatar
KTM
Yes. They aren't compatible yet. I have checked in there forums, seems like Comodo is coming with Vista compatibility soon.
But dreams didn't mention that he has Vista!
Kiran Kumar R
Old 30-05-2007, 10:41 AM   #18 (permalink)
gxsaurav's Avatar
I am asking about my use man. Anyway, downloading KIS right now, all I need is firewall, not even an AV, so I hope KIS has an option not to install anything else.
about.me/gxsaurav
gxsaurav is offline
Old 30-05-2007, 10:49 AM   #19 (permalink)
Kiran.dks's Avatar
^Okkk...
For Vista, KIS remains the best choice.
Kiran Kumar R
Old 30-05-2007, 09:41 PM   #20 (permalink)
Gracias Senor
dreams's Avatar
K Guys.. finally i removed avast installe Kaspersky Internet Security.. Its workin like a charm..thnx for all ur responses.
dreams is offline
Old 30-05-2007, 09:48 PM   #21 (permalink)
Rebooting
Opps.. I think u will b dissappinted.. i think along with the Firewall, KAV is a nessesary for the Suite !!! how ever after installation u may turn any option of feature off !!!
rebooting
ChotoCheeta.com
Old 30-05-2007, 10:53 PM   #22 (permalink)
gxsaurav's Avatar
Hmm...downloaded, lets see if KIS 7 slows my rig or not.
KAV 6 used to slow it a lot.
about.me/gxsaurav
gxsaurav is offline
Old 30-05-2007, 11:01 PM   #23 (permalink)
I have Yolks not Brains!
eggman's Avatar
Don't worry. It won't.......I'm using it and very happy
Y U NO ALLOW PICTURES IN SIGNATURES?
eggman is offline
Download Kaspersky Anti-Virus 7.0 and Kaspersky Internet Security 7.0 for Win Vista Third Eye Technology News 31 22-10-2007 12:18 PM
Avast or AVG? kadal27 Software Q&A 17 17-10-2006 06:07 PM
Avast! Vs AVG samrulez Software Q&A 35 22-05-2006 10:02 PM
avast! 4.7 pro MysticHalo QnA (read only) 14 08-05-2006 02:25 PM
