Old 29-05-2007, 09:48 AM   #1 (permalink)
kumars's Avatar
Default Help me with Blog!!
Hi,
I have registered a domain name at indiatimes. Now I want to upload a web page which will bear my registered domain name address. I thought of using blogger.com page as a web page. How do I link my domain name with it? I mean when I type my domain name then it should automatically redirect to the blogger page.
Kumarpal Shah
kumars is offline
Old 29-05-2007, 10:57 AM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Help me with Blog!!
Hi,
Do you get Domain Managment with Indiatimes? I havent tried them ever so i am not sure.
Anywayz, if you do....add a new CNAME record for ghs.google.com.
More Info here
http://help.blogger.com/bin/answer.py?answer=55373
If you dont get DNS Management from Indiatimes....use EveryDNS.net. This will help you how to do it
http://help.blogger.com/bin/answer.py?answer=58317
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 29-05-2007, 12:11 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
yes with EveryDNS.net one may do it... !!
I would point another option like simple html url redirection
where at ur index/public/www directory u place a index.html file with this as content !!!
<html>
<head>
<meta http-equiv="REFRESH" content="0; URL=http://your.com/address">
</head>
</html>
it will redirect the visitor to the address u specify
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 29-05-2007, 12:32 PM   #4 (permalink)
Host4Cheap.org
<html>
<head>
</head>
</html>
But if you have bought hosting along with the Domain to place that Redirection page....i think then it will be better to host your own blog than to use Blogger. Gives more freedom for customizations
Old 29-05-2007, 01:23 PM   #5 (permalink)
kumars's Avatar
I have made the settings as per the instructions. But am not sure about one thing. In the name servers list of Indiatimes I have added ghs.google.com and in the custom domain name i have given the domain name on which i wish to redirect the blog.
First of all have I done the right settings?
Secondly: Nothing seems to be working. But it says it may take upto 48hrs for name server to be updated.
Kumarpal Shah
kumars is offline
Old 29-05-2007, 01:31 PM   #6 (permalink)
Host4Cheap.org
For using CNAME record you need DNS Managment from Indiatimes.
ghs.google.com << is not a Nameserver.
If there is no DNS Management from Indiatimes....you will have to use thirdparty DNS Managment for e.g EveryDNS.net
Old 29-05-2007, 02:39 PM   #7 (permalink)
kumars's Avatar
yes i have done everything according to the instructions for EveryDNS.net.. BTW should i check on Allow all under Afxr Control @ EveryDNS.net and now what do I do further?
Sorry Axfr control
Kumarpal Shah
kumars is offline
Old 29-05-2007, 04:28 PM   #8 (permalink)
Host4Cheap.org
Do what is mentioned under that guide. Also post your domain here so we can check if DNS settings are correect
Old 29-05-2007, 06:17 PM   #9 (permalink)
kumars's Avatar
Alright.. My domain id is www.dialwish.com
Thanks a million for all ur time.. Appreciated..
Kumarpal Shah
kumars is offline
Old 29-05-2007, 09:44 PM   #10 (permalink)
Host4Cheap.org
Something is seriously wrong with DNS setting. I just checked here and all namerservers timeout
http://www.dnsstuff.com/tools/dnstim...ish.com&type=A
Old 31-05-2007, 05:29 PM   #11 (permalink)
kumars's Avatar
I have changed the settings on Indiatimes.. The nameserver on Indiatimes is set to default.. Now what to do?
Kumarpal Shah
kumars is offline
Old 31-05-2007, 05:36 PM   #12 (permalink)
Host4Cheap.org
No offence, but you have paid Indiatimes....contact their support Its your right.
Old 31-05-2007, 06:16 PM   #13 (permalink)
Rebooting
For immidiate solution Try the one i said. and for those Advance control option, as Sukhdeep said contact IndiaTimes !!
rebooting
ChotoCheeta.com
Old 31-05-2007, 08:21 PM   #14 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
better still buy some hosting or get some free hosting from ur frnd n then use your hosting NameServer to point to your blog . it'll be much more customizable n better than blogger
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 31-05-2007, 08:57 PM   #15 (permalink)
Host4Cheap.org
Agreee, and suggested him that already
Old 01-06-2007, 10:18 AM   #16 (permalink)
TechTin.com
ravi_9793's Avatar
I can give a trial hosting of 1 month.If you get safisfied..than either purchase from me or shift to free hosting plans.
Details of the plan can be read from here : http://www.TechieHost.org
ravi_9793 is offline
Old 07-06-2007, 11:06 AM   #17 (permalink)
kumars's Avatar
Thank you Very much Folks.. Special thanks to SukhdeepSinghKohli.. Well now i want to remove the blogger strip, which is on the top. How do I do it?
Kumarpal Shah
kumars is offline
Old 07-06-2007, 01:15 PM   #18 (permalink)
Host4Cheap.org
No Problem I didnt understand, what strip you talking about
Old 07-06-2007, 01:18 PM   #19 (permalink)
kumars's Avatar
This strip is located on the top.. It has Flag Blog, search blogs and all that.. How to remove or edit that as per our requirements..
Kumarpal Shah
kumars is offline
SUGGESTION: Best Blog Site for Starting a Blog Vishal Gupta QnA (read only) 43 20-09-2007 08:59 PM
Best Blog adi87 QnA (read only) 7 29-05-2006 09:15 PM
what is a blog? drgrudge QnA (read only) 8 02-10-2004 02:38 PM
