Old 28-05-2007, 04:32 PM   #1 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Red face Azureus At Startup
hey buddies...
i wanna start up azureus when my windows startup ...but i unable to c any such option in the interface options of azureus...
so how can we do that ? Azureus v2.4
Thnx
BlackBerry7100g.
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 28-05-2007, 05:08 PM   #2 (permalink)
sachin_kothari's Avatar
Default Re: Azureus At Startup
This is where applications that startup with windows are stored.
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run
Simply create a key with the name and path of the application u want to startup with windows.
sachin_kothari is offline
Old 28-05-2007, 05:44 PM   #3 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
This small Application might help you
http://www.mlin.net/StartupCPL.shtml
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 28-05-2007, 06:00 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Uh .. Cant you just drag the shortcut icon into the Startup folder of Start > All Programs ? World's getting complicated ..
Harsh J
www.harshj.com
QwertyManiac is offline
Old 28-05-2007, 10:25 PM   #5 (permalink)
if we add only the azureus.exe to startup..then it doesn't gets started as it requires .jar files.....so i added all its files [ except uninstallation ] to the startup ..query solved
Old 31-05-2007, 12:12 AM   #6 (permalink)
Commander in Chief
Weird, a simple shortcut to Azureus works perfectly fine here. It might be issues with the Java paths at your end perhaps.
Harsh J
www.harshj.com
CheckDisk running during starup guhanath Software Q&A 2 05-04-2007 10:58 PM
Azureus or other mak1012 QnA (read only) 49 12-09-2006 12:02 PM
azureus problems varunbhide QnA (read only) 2 24-08-2006 03:34 AM
Azureus NAT error in FC4 legolas Open Source 4 02-04-2006 05:39 PM
Azureus ???? saROMan QnA (read only) 11 07-06-2005 07:37 PM
