Originally Posted by kunwar
IS it possible that the laser waveength will get more reduced or have we reached the maximum limit? Also in a DVD Writer is only the laser different or are the other equipments also different as in is it possile to replace the 780 nm laser of VCD with 650 nm laser for DVD?(i dont think so but whats the harm in getting another opinion/s)
If that were possible, people wouldn't need to buy DVD drives now, would they? The costs incurred in "changing" a CD drive (its not just the laser that changes, a lot of the architecture, including the controller chips, change) into a DVD drive would make buying 2 DVD drives a cheaper option.
As for the wavelength issue, Blu-Ray drives are already in sale that use 405nm blue lasers. Its closest competitor, HD-DVD (which looks like it might turn into the domainant technology) uses the same 650nm laser but a more efficient compression algorithm to achieve greater data densities. Look up Google for more information.
