Old 28-05-2007, 12:11 PM   #1 (permalink)
tech_cheetah's Avatar
Default unable to share files between two PCs
I am unable to copy the shared files on from one PC to other thru a LAN cable ..
It shows the shared folder in the workgroup 'MSHOME' and also shows the shared folder on each of the PCs .. I am even able to connect thru the RDC on each of the PCs .. but when i try to access the shared files it gives all sorts of errors like "the server is not started" or "the RPC failed" or "the source is no longer available" ..
I have started up all the necessary services on both the PCs .. turned off the firewall on both .. But still the same problem
Does anybody know what i am missing ..
Be honest . By that way u can be sure that the world is short of atleast one rascal.
tech_cheetah is offline
Old 28-05-2007, 12:45 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: unable to share files between two PCs
Make sure non of the PC has any virus, and All Firewall is truned of... Turn of the AVS too...
Make sure they are on Same Work group...
now, in both PC, turn off the simple file-share...
Go to tools and then Folder option,
Now Go to the view tab. Scroll down and make "Use simple file sharing" unchecked.
Now share the every drive with Full allowed Permission.... Note that Share name X$ (where x is the drive letter) is default share and must be turned on...
Now Click on New Share, give a name, go to permission, and allow full control to every one !!!!
Once u do it, set up the network, like this, on both PC
Go to Network connection, Right click on LAN Connection ICON go to Properties...
Now go to TCP/IP settings
and Enter IP range as this,
IP Address - 192.168.0.1 (192.168.0.1 for the server and 192.168.0.xx for the Nods)
Subnet Mask - 255.255.255.0
Default GetWay - ur ISP getway address if u are sharing net too
DNS Address - For Server its the ISP address.. for NODs enter 192.168.0.1
ALT DNS Address - For server its the ISP DNS.. for NODs Leave it blank
restart the systems, double check all settings like Firewall, IP address, Ping Both from each other !! and try to access now...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 28-05-2007, 08:04 PM   #3 (permalink)
The problem is still there .. it opens the shared folders sometimes .. and next second it says "the resource is no longer available" or "RPC failed" or "Server not started'
Old 28-05-2007, 08:11 PM   #4 (permalink)
Rebooting
As I said, Make sure, No virus, please run a HijacThis scan on both PC and Attch or Post the log file here, also No Firewall / AVS (Due to som avs's Network procetion) is running....
also Check the Service settings on both PC, is there any needed Service is stoped or not...
rebooting
ChotoCheeta.com
Old 29-05-2007, 07:33 AM   #5 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Offtopic: Cheeta answering cheetah.
navjotjsingh is offline
Old 29-05-2007, 07:42 AM   #6 (permalink)
TheSaint
NucleusKore's Avatar
Please turn of any internet connections for safety, and uninstall the firewalls in both systems, reboot, and then do the above steps
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 29-05-2007, 10:07 PM   #7 (permalink)
got the culprit ..
there was one option which i unchecked and it is working now ..
In My Computer -> Properties -> Computer Name -> change -> More -> " Change Primary DNS suffix when domain membership changes "
Thanks - Choto Cheeta
Old 29-05-2007, 10:11 PM   #8 (permalink)
Rebooting
strange as u said u were in WorkGroup Network.. !! What were u doing at Domain controls ??
anyway never mind, as ur problem got solved. !!!
rebooting
ChotoCheeta.com
Unable to share Files Thru Ethernet. Yoda Software Q&A 2 03-03-2007 04:27 PM
Unable to open .chm files:Plz help rakeshishere QnA (read only) 26 25-07-2006 04:05 AM
Unable to share files over wi-fi ashish827 QnA (read only) 7 13-10-2005 01:40 AM
How to connect to computer to share files? divyadbzgt1 QnA (read only) 2 22-08-2005 01:33 PM
HOW CAN I SHARE MY FILES HERE IN THE FORUM drsood123 Internet & WWW 4 12-06-2005 02:10 AM
