Old 28-05-2007, 09:49 AM   #1 (permalink)
Default UNdeletable file
I think err this post is made in wrong section . .. I was unable 2 find a section for programming...
Its some thing like - " i want to create a file which cannot be deleted.. " - an order from my clients --oops ...
Now the actual scenario --
I am having an appln and im creating a log file when the appln is running... NOw i want that log file to be undeletable by others ... >>.>>" the program has to be run in the Admin mode..."
How can i create such a file which cannot be deleted ...
DIGIT Techies plz help
vivekphlp is offline
Old 28-05-2007, 08:11 PM   #2 (permalink)
Default Re: UNdeletable file
Read this month digit tips and trick it can help you.
abhijangda is offline
Old 29-05-2007, 12:53 AM   #3 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Make that file attributed as system file .. It wont be visible...
On the command prompt type this :
attrib +h +s yourfile {press enter}
Should work
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 29-05-2007, 10:00 AM   #4 (permalink)
Frnds it is something like a log file. .. . so that it cant be edited nor be deleted. . . Whenever a user logs to my applictaion, the log file is created/ appended with the login details. He shouldnot able to change the contents later .. .
Log file permission that i need to add -
REad - Eveyone
Write - Only thro my appln(working fine)
Delete - Only thro my appln(admin)
What 2 do???
Should work
tried that one but it will be just hidden .. "easily deletable" .. .
To convert a .bat or a .vbs file into an executable .exe file without any software mneo Tutorials 4 03-06-2007 11:13 PM
Folder undeletable thunderstorm_08 QnA (read only) 8 29-01-2007 08:57 PM
UNdeletable folder!!!!!???? sagar_coolx QnA (read only) 8 01-04-2006 06:07 PM
Change File size in MB instead of GB in properties of a File rachitar QnA (read only) 4 24-11-2005 09:46 AM
