Old 19-02-2005, 08:45 AM   #1 (permalink)
Default Mandrake 10.1
I tried installing the mandrake linux supplied with the digit in my system. The installation all went fine.
The problem happens when i boots. Immediately after installation when i tried to boot the loading gets hung near4 the network detection point says waiting for eth0. I have a LAN connected computer.
After lot of unsuccessfull reboots i disabled the LAN and tried, it when forward from the point and booted but it did not load the GUI and only command entering prompt came asking user name and password, after entering both nothing happened
I tried reinstalling again but the same problems continued.
I definetly need my LAN enabled and i would love to use the GUI.
My system is a P4 3.0Ghz, Intel 915, XFX nVidia 6800GT 160GB SATA Hard Disk, Onboard LAN, 1GB RAM
Pls Help And Thanks in advance
shriekers is offline
Old 22-02-2005, 10:56 PM   #2 (permalink)
this might help the gui prob
http://mail.lug.lk/lurker/message/20...2bf69d.en.html
http://iew3.technion.ac.il/CC/Comp_n...in/xtroub.html
try setting the video card as vesa initially to get into gui and then install nvidia drivers , which might be in their site .
regarding the eth card . disable and disconnect the card and cord . reenable it and let it run autoconfig during boot up , but set it up as auto settings , without specifing the ipaddress . once ur able to go into gui without a hitch , change the ip and connect the eth cable
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
