Old 26-05-2007, 12:19 PM   #1 (permalink)
Default Is these possible?OMG
I have sony DVD writer DUAL LAYER.My problem is My drive reads all type of disc.And when i try to burn a file when i use sony CD or DVD mean it writes and read the files after writing and works fine.But when i use another branded CD or DVD it writes the data but never READ's in my PC and my friends PC also it not reads...what could be the problem?If it's hardware failure mean writing and reading of sony cd and dvd also must not work.what could be the exact problem?
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
Old 27-05-2007, 11:44 AM   #2 (permalink)
clmlbx's Avatar
Default Re: Is these possible?OMG
try different brands
how many cd have u tried ??
I had problem with my sony dvd+rw's.
all 5 that comes in a box were faulty . becuase I burned it well then checked all ok but when I try to run it second time all ............
all were faulty and I had to threw them all .
and loss of 5 x 4.7 gb ==
all data loss
so try different brands and some more cd's
clmlbx is online now
Old 27-05-2007, 11:54 AM   #3 (permalink)
pro
pro's Avatar
also check the writer.... if you are burning with nero check whether you have check marked write simulation instead of burning.
i had an experience where the writer just emulated the burning process even as the simulation option was unchecked. hence all CDs were empty, faulty writer of course.
everything starts with a zero and ends in one.
pro is offline
