Old 25-05-2007, 10:01 PM   #1 (permalink)
[A]bu's Avatar
Default Writing a CD
Can we write a CD-RW form DVD-RW????
Do or Die
http://www.hamrobrt.com/howto-install-flash-player-in-ipad/
[A]bu is offline
Old 25-05-2007, 10:07 PM   #2 (permalink)
prasad_den's Avatar
Default Re: Writing a CD
^^ I don't understand what you are asking... Please be more specific..!!
prasad_den is offline
Old 25-05-2007, 10:21 PM   #3 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Yes you can
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 25-05-2007, 10:22 PM   #4 (permalink)
The Unknown's Avatar
Yes, but it will require about 7-8 CDs depending on the capacity of CD-RW and DVD-RW. For example take DVD-R and CD-R. CD-R cap. is 700 Mb and DVD-R cap. is 4.9 gb. so to write 4.9 gb into cds it will require about 7-8 cds. Just Calculate. 4.9*1000/700=7
KDE on ArchLinux
The Unknown is offline
Old 25-05-2007, 11:01 PM   #5 (permalink)
Arsenal_Gunners's Avatar
^^I think he is asking about writing a cd from DVD RW drive.
Arsenal_Gunners is offline
Old 25-05-2007, 11:57 PM   #6 (permalink)
ashfame's Avatar
yup he is askin dat & he can do it for sure!
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 26-05-2007, 12:01 AM   #7 (permalink)
"The Gentleman"
vish786's Avatar
weired ??? check ur dvd manual or box its written clearly their.... whether u can write cd/dvd or both
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 26-05-2007, 11:23 AM   #8 (permalink)
Yup, it is also possible.
KDE on ArchLinux
Old 27-05-2007, 11:48 AM   #9 (permalink)
pro
pro's Avatar
no no its not possible.....please exchange your dvd drive with my CD/RW
sorry ,just joking. yes it is possible... no doubt.
everything starts with a zero and ends in one.
pro is offline
Writing not done kumarn_2004 QnA (read only) 2 30-03-2007 03:01 PM
DVD writing srimaya_rath Software Q&A 11 06-12-2006 02:31 PM
CD writing help naru QnA (read only) 3 05-08-2005 08:34 PM
Help in DVD Writing stalin QnA (read only) 7 10-05-2005 11:02 PM
cd writing noblefriend2002 QnA (read only) 2 20-08-2004 06:03 PM
