Old 25-05-2007, 05:47 PM   #1 (permalink)
pro
pro's Avatar
Question necessary to keep all j2SE runtime enviroment updates?
is it necessary to keep all j2SE runtime enviroment updates? i can see big updates like j2se runtime enviroment update 5,6,8. they each have 150 MB size. can i install 5th and 6th one and keep 8th one?? see attachment for details
everything starts with a zero and ends in one.
pro is offline
Old 25-05-2007, 06:09 PM   #2 (permalink)
You gave been GXified
gxsaurav's Avatar
Default Re: necessary to keep all j2SE runtime enviroment updates?
Just download the latest one. Uninstall all previous versions & install the latest.
about.me/gxsaurav
gxsaurav is offline
Old 25-05-2007, 06:23 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: necessary to keep all j2SE runtime enviroment updates?
simple go to www.sun.com you will find the latest one
satyamy is offline
Old 26-05-2007, 04:19 PM   #4 (permalink)
pro
pro's Avatar
so i have to do this every time... uninstalling older versions and instaliing new ones?
pro is offline
Old 26-05-2007, 05:14 PM   #5 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
I havent tested this Installer, but sometimes, the New Installers will upgrade it for you
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 27-05-2007, 11:04 AM   #6 (permalink)
The Researcher
Sometimes the old J2se is necessary for the working of certain applications. I found out that the upload process of the Department Company affairs, New Delhi, requires the old one.
Ramakrishnan is offline
Old 27-05-2007, 11:23 AM   #7 (permalink)
pro
pro's Avatar
they end up filling C drive , sun should have cleared this mess by modifying installer to remove unnecessary older updates....
pro is offline
Finding J2SE 5.0 SDK ashu888ashu888 Software Q&A 13 05-08-2006 10:31 AM
FAVORITE DESKTOP ENVIROMENT vignesh Open Source 39 11-09-2005 06:04 PM
Sun lashes out at open source J2SE Calcatian Open Source 3 24-05-2005 09:41 AM
Java Runtime Enviroment 5.0 Update 2 allindrome QnA (read only) 1 25-03-2005 02:28 PM
Require Oracle 10G & J2SE on CD to run compiere erp+crm Gautam Open Source 4 16-02-2005 01:11 PM
