Old 25-05-2007, 04:39 PM   #1 (permalink)
ramprasad's Avatar
Unhappy Problem with View in My Computer
Hi,
When I click on My Computer icon, I get a list of all drives and et all, as usual on the screen.
Butthe problem is, It shows as if the 'Folders' option is always enabled.
I mean to say that there is a pane on to the left showing the same components of My COmputer in a tree style.
Same is the problem with Control Panel.
Whenever I click any drive in My COmputer, the resultant drive also openss in the same manner with a tree view in the left pane.
Few months ago, I was fiddling with registry entries. I feel after this only, the problem has started........
Any help would be appreciated.
ramprasad is offline
Old 25-05-2007, 04:59 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Problem with View in My Computer
Ur problem sounds similer to this one, refer here, Context Menu Problem. Please Help.
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 25-05-2007, 06:06 PM   #3 (permalink)
ramprasad's Avatar
Thanks Choto Cheeta
I will try that, as my comp is at home...
And guys, keep puring in some other methods also..
Old 28-05-2007, 06:54 PM   #4 (permalink)
ramprasad's Avatar
that worked....
Thanx a lot Choto Cheeta
Old 28-05-2007, 07:27 PM   #5 (permalink)
Rebooting
Originally Posted by ramprasad
that worked....
Glad to help
rebooting
ChotoCheeta.com
Fresh View -organize & view multimedia files s18000rpm QnA (read only) 4 29-12-2006 08:14 PM
How to view the saved contacts on the computer??? maharajadhiraj Mobiles and Tablets 3 02-07-2006 11:25 AM
Thumbnail View Problem ashishkhetriwal Software Q&A 9 04-06-2006 01:05 AM
Problem in computer mako_123 QnA (read only) 11 23-02-2006 01:31 AM
Problem with computer system. hbafna Hardware Q&A 2 05-12-2005 06:23 PM
