Old 25-05-2007, 01:51 PM   #1 (permalink)
pritish_kul2's Avatar
Default Folder Sending Site
Can i send huge folders to a mail using any site. Folders not files
pritish_kul2 is offline
Old 25-05-2007, 01:53 PM   #2 (permalink)
prasad_den's Avatar
Default Re: Folder Sending Site
Compress it with winrar and send the rar file..!!
prasad_den is offline
Old 25-05-2007, 01:54 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
That;s the Only option, though I would say use ZIP format...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 25-05-2007, 01:56 PM   #4 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
yes...install winrar....right click on folder n choose add to :foldername".rar
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 25-05-2007, 04:06 PM   #5 (permalink)
jal_desai's Avatar
Use WinRar... u will get two benifits.. 1. u will be able to send the whole folder and 2. ur files will be slightly compressed too.
TechExplorer.in
jal_desai is offline
Old 25-05-2007, 04:54 PM   #6 (permalink)
Rebooting
I would still suggest .ZIP format over .RAR,
Reason, simply because u dont need to install a software at receiving end to de-compress the file... to Techi its nota problem but with NON Techi and Cross plat form, ZIP to me is the best
rebooting
ChotoCheeta.com
Old 25-05-2007, 05:49 PM   #7 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
How about a SFX LOL
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 25-05-2007, 05:53 PM   #8 (permalink)
i recommend u to upload ur files to www.mediafire.com totally free n supports download managers...
Unlocking any folder from folder locker [A]bu Tutorials 9 16-12-2008 03:03 PM
How to hide folder in windows XP without using folder guard sridatta Software Q&A 23 06-12-2006 06:32 AM
sending sms through internet amey_dude Mobiles and Tablets 16 17-09-2005 06:40 PM
Free S.M.S Sending Script On Your Site Creative-Eye QnA (read only) 5 25-08-2005 08:16 PM
own number sending!!! aku Mobiles and Tablets 13 20-07-2005 09:42 AM
